6815 Discussions
how to count the number of colors in an image
crao
Is there any IPP function that can count the number of unique colors in a image ROI? Moreover, can it provide the RGB value of those colors? Thanks a lot.
crao
shyaki
Quoting - crao
crao
Why need IPP function for this simple work?
Mikael_Grev
Quoting - shyaki
If you think this is simple I'm affraid you don't fully understand the problem, the possible per-CPU performance gains or that IPP is actually a set of low level optimized functions solving exactly these kinds of problems.
Cheers,
Mikael
Cen_Rao
Quoting - shyaki
it requires to loop through each pixel and record the pixel value. when you work on HD resolution images and 256*256*256 size color space, simple loop become too slow.
I think OpenMP and SSE can speed up the process significantly, which are the IPP specialty. I could do it with my own manu coding, but it takes too much time.
Current IPP histogram functions only work on 1-channel images, there is no real 3-D histogram IPP functions for RGB images. I can not think of another way to get the result.
