6683 Discussions
how to resample audio from 44.1 HZ to 48 HZ
shyaki
Can you tell me how to resample the audio from 44.1 hz to 48 hz in the block-wise way?
I used the multi-rate filter and the sample code from the IPP book.
The quality was not good and the transition between blocks seemed not smooth and I could hear clicking effects.
Any sample code would be appreciated. Thanks.
shyaki
We used to use ippsResamplePolyphaseFixed_16s in IPP6.0, but since the new IPP7.0.2 does not include it, we would like to replace it with other method. I think we may need to use the multi-rate filter. Does anyone know how to repace ippsResamplePolyphaseFixed_16s by something else on a one-to-one base? I would like to implement
ippsResamplePolyphaseFixed_16s()
; multi-rate filers
Many thanks in advance.
