ipp installation under linux
Saman_T_
After running ipp setup software is installed inside /opt/intel
To add the library to my programming IDE (QT), I added this path to the project file:
/opt/intel/composer_xe_2013_sp1.0.061/ipp/lib/ia32
But, unfortunately, I still cannot find the ipp.h include file in my program.
is there anything wrong with the path? how to resolve this?
Gennady_F_Intel
Can you see this directory  /opt/intel/composer_xe_2013_sp1.0.061/ipp/include/   on your system?
Saman_T_
ls /opt/intel/composer_xe_2013_sp1.0.061/ipp/include/
ippac.h  ippch.h    ippcv.h  ippdefs.h  ippgen.h  ippi.h  ippm.h  ippsc.h  ippvc.h       ippvm.h
ippcc.h  ippcore.h  ippdc.h  ippdi.h    ipp.h     ippj.h  ippr.h  ipps.h   ippversion.h
I included the file: #include "/opt/intel/composer_xe_2013_sp1.0.061/ipp/include/ipp.h"
Now, i get another link error, undefined reference to`ippsGetLibVersion'  and  ld returned 1 exit status
To solve this I added the library LIBS += -L/opt/intel/composer_xe_2013_sp1.0.061/ipp/lib/ia32
but it did not help!
Gennady_F_Intel
pls read user's guide to see how to build your application with IPP.
Saman_T_
yes, i will.
Saman_T_
I have problem building a sample application. I did the following, could anyone check the steps and correct them: (ipp-8)
Set environment:   export ipp_install_path="/opt/intel/composer_xe_2013_sp1.0.061/ipp/"
It is mentioned for dynamic link the steps are: For dynamic link, the command is:             $gcc -o main main.c -I <ipp install path>/em64t/include -L <ipp install path>/em64t/sharedlib -lippiem64t -lippsem64t -lippcoreem64t -liomp5 -lpthread -lm
I used this command instead: gcc -o main main.c -I /opt/intel/composer_xe_2013_sp1.0.061/ipp/include -L /opt/intel/composer_xe_2013_sp1.0.061/ipp/lib/ia32 -lippi -lipps -lippcore -liomp5 -lpthread -lm
main.c:1:10: error: #include expects "FILENAME" or <FILENAME>
main.c: In function ‘main’:
main.c:4:1: error: unknown type name ‘IppiSize’
main.c:4:1: warning: excess elements in scalar initializer [enabled by default]
How can I resolve this?
