ipp lead to decrease performance
mmmmm__hamed
hi
i have a system with 15 -750 cpu and windows 8.1 and I use IPP8.2 .
my program have a greate number Array Mul ,Div or sqrt.
i write a small code with ipp and use both ippm and ipps for mul array and compare that code performance with my simple array mul.
my code is this:
    Ipp64f* src=new Ipp64f[200]();
    for(int i=0;i<200;i++)
        src=i; // initialize source array with values
    Ipp64f* res=new Ipp64f[200]();
    double t1=GetTickCount();
    for(int k=0;k<5000000;k++)
        ippsMulC_64f(src,2,res,200);
    double t2=GetTickCount();
    double Ipp_Mul_Time=t2-t1;
            res=src*2;
    double t3=GetTickCount();
    double MyMulTime=t3-t2;
i run this test program and in every test my simple Mul is faster than IPP Mul
i test this program for both small and big arrays and get same result.
i think that i can improve my progarm performance with intel ipp but it happend.
is exist a problem in my test code that lead to this abnormal behavor? or my test result is correct?
mmmmm__hamed
my cpu is i5 -750.
mmmmm__hamed
 hi
my problem is solved
i find that if i mul to floating point number instead 2 , Ipp is faster.
i think in above case ipp doing 64 bit floating point mul and standard mul use another(i dont unknow) simpler operation.
with same operation ipp is winner.
Sergey_K_Intel
Hi!
Please, be careful with measurements like these[:smile:])).
I have seen cases when optimizing compiler (like Intel C/C++) simply ignored some source code (even loops), if found that the results were not used later on.
