ippcore-5.1.dll not found
elevenmice
Hi all,
I just installed IPP5.1 today and installed the tutorials.
I have downloaded the ippdemo.exe and it's source code.
I use VC2005 to compile everything and it's all good.
But when i press F5 to run the demo, I get ippcore5.1.dll was not found. Please reinstall the software.
But i know the dll is there. it's in
D:Program FilesIntelIPP5.1ia32in
when i copy ippdemo.exe to that folder, everthing works fine.
So my question is this, what do i need to change in the project settings so that the demo will compile and run without me having to copy the exe over to that folder?
-chetan
bendeguy
Hi Chetan!
Did you set the environment variables? You can do this by running
c:Program FilesIntelIPP5.1ia32 oolsenvippenv.bat
After this, you have to restart your computer to take effect the changes.
Greetings,
Bendeguy
elevenmice
thank you very much. that solves my problem
