6825 Discussions
ippdc lib missing in intelipp.static.win-x64 target file on nuget.org
daiyicun
did anybody meet the same issue that ippdc lib missing in intelipp.static.win-x64 target file on nuget.org? the current target file downloaded from nuget.org is not include ippdc lib in <AdditionalDependencies> property. which will cause related function unreferenced.  if added into target file <AdditionalDependencies> property, compile will be fine.  not sure it is a mistake or not.   fixed file is attached.
ShanmukhS_Intel
Hi Eason,
Thanks for posting on Intel Communities.
Could you please get back to us with steps to reproduce and a sample reproducer where you are using ippdc lib dependent functionalities as mentioned? It helps us to reproduce the issue at our end and assist you further on that.
Could you please confirm if you have updated the pkg file shared by you with ippdcmt.lib?
Shanmukh.SS
daiyicun
hi Shanmukh
      thank you for following up this issue.  to reproduce is very simple, any ippdc function if you want to call from nuget package will tell you unreferenced.  as I said, ippdcmt.lib is in the package but you forgot to add them as <AdditionalDependencies> in target file.  please compare my modified target file with intel published original version, you will know what I mean.
thanks
eason dai
ShanmukhS_Intel
Hi Eason,
Thanks for sharing the details. We have downloaded the shared NuGet package.  Will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi Eason dai,
We have conveyed your feedback to the concerned team. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi Eason Dai,
We are discussing your issue internally. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi Eason Dai,
Thanks for reporting the issue.  We were able to reproduce it and we have informed the development team about it. We will get back to you with an update.
Shanmukh.SS
daiyicun
that's cool
ShanmukhS_Intel
Hi Eason Dai,
This issue has been fixed in IPP version 2021.8. We would like to request you, kindly check and raise a new thread if the issue persists as this thread would no longer be monitored by Intel.
Shanmukh.SS
