ippiCopy_8u_C1C4R
Adriaan_van_Os
What is ippiCopy_8u_C1C4R supposed to do ? If it is supposed to copy one channel (of a one-channel image) to multiple channels (of a multi-channel image) how is it different from ippiDup_8u_C1C4R ? And in that case, why was ippiDup_8u_C1C4R introduced ?
I noticed by the way that ippiCopy_8u_C1C4R doesn't work (for the supposed purpose) where ippiDup_8u_C1C4R does work.
Adriaan van Os
Chao_Y_Intel
HI Adriaan,
ippiCopy_8u_C1C4R only
copy data from a one-channel image pSrc to only "one" channel of a multi-channel dst image. It you want to  copy one channel (of a one-channel image) to multiple channels, it needs to use ippiDup functions.
Chao
Adriaan_van_Os
Thanks for clarifying this. This is a useful function in itself !
I suggest to change the wording in the manual "Case 5: Copying a one-channel image to a multi-channel image" to "Case 5: Copying a one-channel image to one channel a multi-channel image"
ippiCopy_xx_C1C4R doesn't have a channel parameter, but that doesn't matter much as the channel can be selected through an offset of the pDst parameter.
Adriaan van Os
Igor_A_Intel
Hi Adriaan,
thank you, will be fixed in the manual.
regards, Igor
Adriaan_van_Os
Also I suggest to add ippiDup_16u_C1C4R and ippiDup_32f_C1C4R.
Adriaan van Os
