We are running into a strange issue with ippiDilate/Erode. It runs fine on multiple dev machines with varying vintage but exhibits huge timing numbers on our production PCs
- Dev1- Intel i72700K - 2-3 ms OK,
- Dev2 - Intel i7-8700 OK,
- Production - Intel i9-7940X - Massive overtiming 30-40 ms for same function
We use other filters without issues on the same PC and timing numbers usually correlate with age of Intel chip speed.
OS - Windows 7, Win 10, IPP 2017 Update 3, static linking
Any ideas what might be causing this
Image Size: 1920x540, Kernel Sz= 3x3
Nikhil, could you give us the reproducer which we will use for reproducing the problem on our side with different versions of IPP, OS and CPU?
Apologies for the delay. I will see about getting you a test project
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
Topic Options
