ippiFilterBoxBorderGetBufferSize gives different buffer size in IPP8.2 vs. Ipp9.3
Lars_A_
During the upgrade from IPP 8.2 to IPP 9.3, we noticed that "ippiFilterBoxBorderGetBufferSize" function gives different results.
The input parameters to this function were:
ROI: {X = 0 Y = 0 Width = 2056 Height = 2056}
Mask Size: {Width = 15 Height = 15}
Data Type: ipp32f
Number Of Channels: 1
And the buffer size coming out of this function was:
IPP 8.2: 17843472
IPP 9.3: 827240
Please advise with further information about the root cause to this difference.
I'd appreciate your help in advance
Jonghak_K_Intel
could you please post the snippet of your code for better investigation ?
thank you.
Lars_A_
Thanks for your reply.
The code snippet is as follows (The same for both 8.2 and 9.03):
Size maskSize = new Size(15,15);
int bufferSize;
ippStatus = ippiFilterBoxBorderGetBufferSize(outputImage.GetRoiSize(), maskSize, IppDataType.ipp32f, 1, &bufferSize);
Best,
Lars
Valentin_K_Intel
Hi Lars,
The function ippiFilterBoxBorderGetBufferSize returns the maximum buffer size from out-of-place and in-place cases. The implementation of function ippiFilterBoxBorder_32f_C1R was changed for IPP 9.0.3 for in-place case. So the buffer size for in-place case was changed that leads to changing the returned buffer size.
Valentin
