ippiFilterGauss
j_bossu
Hello and happy new year.
I have a question with the function ippiFilterGauss.
I want to filter an image (Ipp32f) coded in RGB with a gaussian filter.
How to use the function ippiFilterGauss ?
The fuction using border (for example ippiCopyReplicateBorder) must be used ?
Thanks a lot
Jrmie
Vladimir_Dudnik
happy new year for you too:)
you are right, when IPP filter uses border pixels you need somehow define them. For example, you can allocate buffer for your image with some extension, to keep 2 lines and 2 columns more than your image actually use. The method to define those extension pixels can vary depending on your application needs, the simplest one is just to set extended pixels to zero. Or you can use IPP functions like ippiCopyReplicateBorder for other options.
Vladimir
Message Edited by vdudnik on 01-12-2006 12:57 PM
ounim
I want to filter an Image Ipp32f with a gaussian filter. So I follow your advice and try to use ippiCopyReplicateBorder. But ippiCopyReplicateBorder can't copy Ipp32f image!
Is there another ipp fonction to do this? or I will replicate border "by hand" ?
Thank you very much
damien
Vladimir_Dudnik
Hi Damien,
you are right, we do not have special copy function for 32f data type. But as it just copy operation, I think you can use ippiCopyReplicate for Ipp32s data type because of the same size of data element. It is probably not the nice solution, but it should work and work fast.
Vladimir
Intel_C_Intel
Another possibility is to use IPP separable filters with borders ippiFilterRow/ColumnBorderPipeline. You need not image extension with border pixel in this case
The example 9-3 (p 9-55)in volume 2 of IPP manual shows how to organize separable filtering in pipeline manner. In this example 1 row is processed at a time, it could be easily modified to process N rows at a time
Alexander
