Is there a problem within the ippiMinMax_8u_C3R function? Consider the following example:
IppiSize roi;
roi.width = 100;
roi.height = 100;
int step = 0;
Ipp8u c[3] = {255, 255, 255};
Ipp8u min[3] = {128, 128, 128};
Ipp8u max[3] = {128, 128, 128};
Ipp8u* pIm = ippiMalloc_8u_C3( roi.width, roi.height, &step);
ippiSet_8u_C3R(c, pIm, step, roi);
IppStatus status = ippiMinMax_8u_C3R (pIm, step, roi, min, max);
If the image is white (255, 255, 255) and wider than 3 px ippiMinMax will return min = (0, 0, 0) max = (255, 255, 255).
If we try the same using Ipp8u c[3] = {254, 254, 254}; we get min = (254, 254, 254) max = (254, 254, 254).
I am not sure what went wrong here? Any error on my side? The error occurs using Ipp 6.1/7.0 and apparently only using x64. ippiMin and ippiMax are working as expected.
Marcus
IppiSize roi;
roi.width = 100;
roi.height = 100;
int step = 0;
Marcus
Hi Marcus,
Thanks for your report. I see the problem as well. We will some check, and provide feedback.
Chao
The bug is fixed. The correction will be accessible next version.
Thank you for help!
Thank you for help!
