6832 Discussions
ippiMorphOpenBorder_8u_C1R is slower than older IPP version
BaffledCoder
Recently I shifted from IPP 5.3 to IPP 2021.6.2.
While testing for performance, we found out that
ippiMorphOpenBorder_8u_C1R is taking 30% more time than IPP 5.3.
Whereas other functions like ippiDCTFwd_32f_C1R and ippiFFTFwd_RToPack_32f_C1R are faster by 40%.Also, ippiMorphCloseBorder_8u_C1R is faster by 30%
Results for ippiMorphOpenBorder_8u_C1R
For IPP 5.3.3.082 time per 1000 calls is 4730.390188
For IPP 2021.6.2 time per 1000 calls is 6188.637276
What could be the reason for this?
Performance tests were done on the machine supporting AVX 2 instruction set.
BaffledCoder
On AVX 512F, ippiMorphOpenBorder_8u_C1R has an optimization of 12%
Also, while testing for performance, we found that ippiMean_StdDev_8u_C1R is slower than IPP 5.3 by 30%. (AVX 2)
There could be more functions that I will share if found.
EDIT:
In AVX2, there is no optimization in ippiMorphOpenBorder_8u_C1R.
Previously, I was calling allocating work buffer before each call of ippiMorphOpenBorder_8u_C1R using ippsMorphAdvGetSize+ippdMalloc+ippiMorphAdvInit.
Now I am only allocating buffer once for the same ROI and MASK.
and calling ippiMorphOpenBorder_8u_C1R
As a result, the MorphOpenBorder function takes the same time as the previous one.
I am not sure what caused this to happen.
I will be making a reproducer to share all the function which is taking more time in IPP 2021.6.2 compared to IPP 5.3
BaffledCoder
Update:
I have created the reproducer for ippiMean_StdDev_8u_C1R
And think that could be caused due to smaller number of input values.
Please provide a medium if a reproducer is required.
Also, I haven't received any update regarding ippiMorphOpenBorder_8u_C1R.
Shubham Sharma
NoorjahanSk_Intel
Thanks for posting in Intel communities.
Could you please provide us with the reproducer codes using both ippiMean_StdDev_8u_C1R and ippiMorphOpenBorder_8u_C1R? So that we can try it from our end.
Also please let us know how you are measuring the performance along with OS details and Compiler version being used.
Thanks & Regards,
Noorjahan.
BaffledCoder
Hi @NoorjahanSk_Intel ,
Things to be noted:
I have only shared the reproducer for ippiMean_StdDev_8u_C1R
My machine supports AVX 2
OS: Windows 10 Pro version: 22H2
Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz 3.60 GHz
RAM 32 GB 64bit
Here is the link to the reproducer.
I have shared the lib and header file for building IPP2021.6  and  PerformanceTest_IPP project.
If you also need IPP 5.3 project, please email me.
Shubham Sharma
BaffledCoder
Any update on the issue??
NoorjahanSk_Intel
Thanks for providing the details.
We tried the sample code from our end with VS 2022 17.2.6 version and we are facing some issues.
Please refer to the below screenshot for more details.
Could you please help us in resolving this issue by providing the detailed steps to build the code with VS 2022?
Thanks & Regards,
Noorjahan.
BaffledCoder
I think you have added extra space.
Instead of "Visual Studio 17 2022" you have written "Visual Studio 17 2022[SPACE]".
Please check and share if the issue still occurs.
Steps for building
You only have to change the Visual Studio version in the build.py and run it.
Afterward, build the PerformanceTest_IPP project in the release mode.
Shubham Sharma
BaffledCoder
Any Updates @NoorjahanSk_Intel ??
NoorjahanSk_Intel
We have tried it at our end with visual studio and able to build the program successfully(3 succeeded and 0 failed)  but facing some issues while running it
Please find the below screenshot for more details:
Where as with Intel command prompt, we are able to get the results and observed that older IPP version is taking less time than latest Version.
Could you please help us to resolve the error with visual studio?
Thanks & Regards,
Noorjahan.
BaffledCoder
I think you would need to set PerformanceTestIPPEXE as a source project.
At the moment, ALL_BUILD is set as source (Check ALL_BUILD in bold in Solution Explorer)
You will need to right-click on PerformanceTestIPPEXE in the solution explorer and then Set it as Source Project.
Shubham Sharma
BaffledCoder
Any update, @NoorjahanSk_Intel?
Shubham Sharma
NoorjahanSk_Intel
Could you please try with the latest IPP version(2021.7) and let us know if you still observe similar behavior with a reproducer?
Thanks & Regards,
Noorjahan.
BaffledCoder
The issue persists.
Shubham Sharma
BaffledCoder
Any @NoorjahanSk_Intel  Update??
NoorjahanSk_Intel
We have reported this issue to the concerned development team. They are looking into your issue.
Thanks & Regards,
Noorjahan
NoorjahanSk_Intel
Thank you for your feedback. We have provided your feedback to the relevant team. At this moment there is no visibility of when it will be implemented and available for use. Please refer the below release notes for future release
https://www.intel.com/content/www/us/en/developer/articles/release-notes/release-notes-for-oneapi-integrated-performance-primitives.html
Please let me know if we can go ahead and close this case.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan.
