ippiResizeLinear_8u_C1R reads past the end of the source buffer
Beese__Erin
I'm trying to resize an image using ippiResizeLinear_8u_C1R. When I have application verifier enabled, it's telling me that this function is reading past the end of the source buffer. This only seems to occur when the output dimensions are odd. Is this a known issue? I couldn't find any documentation that indicates the dimensions need to be multiples of 2.
Here is the input format/sizes I'm using:
Input: YUV420 610x310
Output YUV420 305x155
Erin
BMart1
New Contributor II
Post a method that reproduces the error. 4:2:0 images are even sided, yes.
Beese__Erin
After further investigation I think it's an error in my resize setup code.
