ippiSampleLine not working as expected
gau_chau
I was hoping to get a little help on why the ippiSampleLine_8uC1R routine is behaving strangely in my code. I am developing an application for which one of the processing is finding the center of a circle/ellipse in an image. I want to write code to extract line information of fixed length at various angles from the image center. For this, I first wanted to familiarize myself with the use of ippiSampleLine_8uC1R function, and am using a 256x256, 8bit, grayscale, synthetic data (attached .raw) to begin with.
What I observe is that for horizontal and vertical lines (0, 90, 180 & 270 deg) the output is exactly as expected. But for any other angle lines (e.g. 20, 40, 60 deg, etc. in my code), the line profile data extracted from the image seems very "squeezed" (attached excel data sheet), and there are lots of initialized values (0's in my case) at the end of the line buffer. I am comparing the results of the ippiSampleLine_8uC1R function with line profile capabilities of ImageJ (or any other image analysis software can be used).
For my image (attached .bmp), the e.g. 40 deg. line is from -- Start pix: (128, 128) & End pix: (212, 198)
Can anyone offer any ideas why this routine would give such unexpected results? Any help quickly would be deeply appreciated.
Thanks in advance,
GC
Here is the core function. You can find the full working code in the attached circle_detect.c file
void circle_detect( char* img_path )
my_img img;
IppiPoint start_pix = {-1, -1};
IppiPoint end_pix = {-1, -1};
void* line_data = NULL;
int num_ele = 0;
int theta_deg = 0;
double theta_rad = 0.0;
int rad_pix = 0;
int img_mid = 0;
int i = 0;
//Create & initialize img
img.size.width = 256;
img.size.height = 256;
img.step = img.size.width * sizeof(Ipp8u);
img.data = ippMalloc(img.size.height * img.size.width * sizeof(Ipp8u));
//Read the image
iret = read_data_raw( img_path, img.data, img.size.width * img.size.height * sizeof(Ipp8u) );
rad_pix = 110;
img_mid = 128;
//Line data: Need memory for at least (num of pixels + 1)
num_ele = rad_pix + 1;
line_data = ippsMalloc_8u(num_ele);
for( theta_deg = 0; theta_deg < 360; theta_deg += 20 )
theta_rad = (3.142/180.0) * theta_deg;
start_pix.x = img_mid;
start_pix.y = img_mid;
end_pix.x = (rad_pix * cos(theta_rad)) + img_mid;
end_pix.y = (rad_pix * sin(theta_rad)) + img_mid;
printf("Ang: %d, Start pix: (%d, %d), End pix: (%d, %d)\\n", theta_deg, start_pix.x, start_pix.y, end_pix.x, end_pix.y);
//Line data: Extract line of data from the image
FuncStat = ippsSet_8u( IPP_MIN_8U, line_data, num_ele );
FuncStat = ippiSampleLine_8u_C1R( img.data, img.step, img.size, line_data, start_pix, end_pix );
for(i=0; i
printf("%03d, ", ((Ipp8u*)line_data));
printf("\\n\\n\\n");
ippFree(img.data);
ippsFree(line_data);
img.data = line_data = NULL;
Igor_B_Intel1
Line lenght in pixels depend on starting and ending points and no more than"max(|pt2.x - pt1.x| + 1, |pt2.y - pt1.y| + 1)". In your case for 40 deg line its length in pixels is 85 so elements in"line_data" with indexes [85,11) stay unchanged. In elements [0,84] stored source image pixels values belonged to the rasterized line.
Igor S. Belyakov
Ying_H_Intel
I havetriedthe code provided by gau_chau. It works asgau_chau's discription.The reasonforthere are lots of initialized values (0's in my case) at the end of the line should be asIgor's explaination.
so there are about max (212-128 +1, 198-128+1)= 85 points on the line. It is theline as the definition. end_pix.x = (110 * cos(40)) + 128;
but the total lengh of line_data was defined as
num_ele =110 + 1;
so other 111-85 pixel on the line_data memorykeepinitial value 0;
rad_pix = 110;
img_mid = 128;
Ying
