ippiScaleC_32s32f_C1R is slower than simple loop
andreypir
Attached is a simple console project that shows that when scaling a matrix ippiScaleC_32s32f_C1R is slower than a simple equivalent C++ code loop. In this example a column from the source matrix is scaled into an output vector. On my PC with i7-7700K the C++ loop is about 20% faster.
Is there any way to improve the ippiScaleC performance?
Gennady_F_Intel
Andrey, how could we check this case? There is no reproducer attached to this thread.
andreypir
Sorry I thought I attached the zip. Here it is.
Gennady_F_Intel
ok, what version of IPP did you compare with?
andreypir
andreypir
ippi.dll shows File version 2020.0.2.1083
Gennady_F_Intel
Yes, it seems there is a problem on the IPP side and this function has to be more optimized. We will escalate the case.
Andrey_B_Intel
Hi Andreypir!
The IPP works better with rectangular ROIs when loads whole SIMD register.
But could you please replace in your code this
for (int n = 0; n < NTESTS_SCALE; n++)
  ScaleWithIPP(Source, nColumns, Dest, nRows, Factor, Shift);
with the next code? I see some speedup at my 64bit Skylake system.
  int dLen = 0;
  int phase = 0;
  ippsSampleDown_32f((Ipp32f*)Source, nColumns*nRows, Dest, &dLen, nColumns, &phase);
  IppiSize roiSize = { nRows, 1 };
  ippiScaleC_32s32f_C1R((Ipp32s*)Dest, nRows * sizeof(__int32), Factor, Shift, Dest, sizeof(float), roiSize, ippAlgHintFast);
andreypir
Hi Andrey,
Thank you. Yes, downsampling then scaling is substantially faster than just scaling, and somewhat faster than a loop:
ScaleWithLoop: 828
ScaleWithIPP 625
on my computer. I think I hoped for a better gain, but this will work.
