ippiWTInv Maximum Image Size?
Joshua_K_
I am trying to use ippiWTFwd and ippiWTInv to compute the haar transform of an image.  The image is already in a size that is powers of 2, so I don't have to worry about replication or extending the image border.  When I call my function on a 256x256 image up to a 1024x1024 image it doesn't cause a problem.  If I try an image that is 2048x2048 or larger, my function will crash in ippiWTInv and return a read access violation at 0x0.
Here is the function I am using, which I pass the image data and the image width/height.
[cpp]
Ipp32f* haarIppi(Ipp32f* inputBuffer, int width, int height)
IppiWTFwdSpec_32f_C1R* pSpec;
IppiWTInvSpec_32f_C1R* pSpecInv;
Ipp32f pTapsLow[2] = {0.7071067811865475f,0.7071067811865475f};
Ipp32f pTapsHigh[2] = {0.7071067811865475f,-0.7071067811865475f};
int lenLow = 2;
int anchorLow = 1;
int lenHigh = 2;
int anchorHigh = 1;
int srcStep = width*sizeof(Ipp32f);
Ipp32f* pDetailXDst = new Ipp32f[width*height/4];
Ipp32f* pDetailYDst= new Ipp32f[width*height/4];
Ipp32f* pDetailXYDst = new Ipp32f[width*height/4];
Ipp32f* pApproxDst = new Ipp32f[width*height/4];
IppiSize dstRoiSize = {width/2, height/2};
int bufSize, bufSizeInv;
Ipp8u* pBuffer;
Ipp8u* pBufferInv;
Ipp32f* pDstInv = new Ipp32f[width*height];
IppiSize roiInvSize = {width/2, height/2};
int stepDstInv = width*sizeof(Ipp32f);
int approxStep, detailXStep, detailYStep, detailXYStep;
approxStep = detailXStep = detailYStep = detailXYStep = width/2*sizeof(Ipp32f);
//perform forward wavelet transform
ippiWTFwdInitAlloc_32f_C1R ( &pSpec, pTapsLow, lenLow, anchorLow, pTapsHigh, lenHigh, anchorHigh);
ippiWTFwdGetBufSize_C1R(pSpec, &bufSize);
pBuffer = ippsMalloc_8u(bufSize);
IppStatus forward = ippiWTFwd_32f_C1R (inputBuffer, srcStep, pApproxDst, approxStep, pDetailXDst,
detailXStep, pDetailYDst, detailYStep, pDetailXYDst, detailXYStep,
dstRoiSize, pSpec, pBuffer);
if(forward!=0)
qDebug() << "something failed in forward Xform";
//initialize inverse specs
ippiWTInvInitAlloc_32f_C1R (&pSpecInv, pTapsLow, lenLow, anchorLow, pTapsHigh, lenHigh, anchorHigh);
ippiWTInvGetBufSize_C1R(pSpecInv, &bufSizeInv);
pBufferInv = ippsMalloc_8u(bufSizeInv);
//perform inverse wavelet transform
ippiWTInv_32f_C1R( pApproxDst, approxStep, pDetailXDst, detailXStep, pDetailYDst, detailYStep, pDetailXYDst,
detailXYStep, roiInvSize, pDstInv, stepDstInv, pSpecInv, pBufferInv);
ippiWTInvFree_32f_C1R (pSpecInv);
ippiWTFwdFree_32f_C1R (pSpec);
return pDstInv;
[/cpp]
Joshua_K_
I want to note that it only seems to crash when the image width > 1024.  I can run the code on images which are 8192x1024 etc., but if I try something like 2048x2048 or 1024x8192, it will get an invalid acess error in the inverse function.
SergeyKostrov
Valued Contributor II
Joshua, Thank you for the test case. Now, could you take a look how much memory is allocated on your platform just before the crash happens? ( look at the Task Manager if you're using Windows, or another memory viewing utility if on Non WIndows ). I would like to know Memory Usage ( physical ) and VM Size ( virtual ) numbers when the image size is greater than 2048 by 2048 ( 16MB ).
Joshua_K_
It looks like the process uses ~70MB of memory when running on a 1024x1024 image, ~130MB when (crashing) to use a 2048x2048 image and ~300MB for a 8196x1024 image which does not crash.  I attached the task manager memory details for each scenario.  If there is a hidden buffer limit with the inverse WT function, then I may just split my large image  into smaller sections for processing.
SergeyKostrov
>>... If there is a hidden buffer limit... There are two more memory related things: - Stack Reserve and Commit values ( look at Linker Settings ) - Virtual Memory Min and Max values ( look at System applet in Control Panel )
Joshua_K_
For virtual memory Min and Max, I have Min as 16MB and Max as 6135MB.
I am unsure about the stack reserve/commit, but I am using qMake with QT Creator to do the linking and I believe the default stack size is set with /Zm200.
SergeyKostrov
>>For virtual memory Min and Max, I have Min as 16MB and Max as 6135MB... Min value is too low. Could you try to set: Initial size (MB): 2048 ( that is 2GB ) Maximum size (MB): 8192 ( that is 8GB ) in System applet. >>...I am unsure about the stack reserve/commit, but I am using qMake with QT Creator to do the linking and >>I believe the default stack size is set with /Zm200. What C++ compiler ( or IDE ) do you use?
