6822 Discussions
ippiYCbCr420ToYCrCb420_8u_P2P3R and ippiYCbCr420_8u_P2P3R are the same
BMart1
New Contributor II
ippiYCbCr420ToYCrCb420_8u_P2P3R and ippiYCbCr420_8u_P2P3R are the same function, even in the order of the parameters. They should share underlying code.
Bruno
ShanmukhS_Intel
Thanks for posting on Intel Communities. Please find the description of color conversion functionalities below.
YCbCr420ToYCrCb420
This function converts the 4:2:0 two-plane source image pSrc to the 4:2:0 three-plane image pDst. The first plane of the source image pSrcY contains luminance samples Y0, Y1, Y2, ..., the second plane pSrcCbCr contains interleaved chrominance samples Cb0, Cr0, Cb1, Cr1, .... The destination image pDst has the following order of pointers:Y-plane, Cr-plane, Cb-plane
YCbCr420
This function converts the 4:2:0 three-plane source image pSrc to the 4:2:0 two-plane image and vice versa. Two-plane image contains luminance samples Y0, Y1, Y2, .. in the first plane, and interleaved chrominance samples Cb0, Cr0, Cb1, Cr1,... in the second plane.
We would like to request you to elaborate your details a bit, so that it helps us in understanding the issue better.
Shanmukh.SS
BMart1
New Contributor II
It's just that the functions do the same thing and waste space.
ShanmukhS_Intel
Hi Bruno,
Thanks for reporting. We will get back to you soon with an update on this.
Best Regards.
Shanmukh.SS
ShanmukhS_Intel
Hi Bruno,
Thanks for sharing the feedback. We have conveyed the same to the development team. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi Bruno,
We are discussing your issue internally. We will get back to you soon with an update.
Apologies for the delay in response.
Shanmukh.SS
ShanmukhS_Intel
Hi Bruno,
We are working on your feedback internally, as mentioned earlier. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi Bruno,
Thanks for sharing your feedback.
We have informed the development team about it. We will get back to you soon.
Shanmukh.SS
ShanmukhS_Intel
Hi Inetsat,
Please find the below information regarding ippiYCbCr420ToYCrCb420_8u_P2P3R and ippiYCbCr420_8u_P2P3R.
For ippiYCbCr420ToYCrCb420_8u_P2P3R, its source is two-plane: Y + interleave Cb and Cr convert to three-plane: Y + Cr + Cb without interleave for Cb and Cr
For ippiYCbCr420_8u_P2P3R , its source is two-plane: Y + interleave Cb and Cr convert to three-plane: Y + Cb + Cr without interleave for Cb and Cr
The difference is the order in output, the First is Y, then Cr, and then  Cb, the second is Y, then Cb, and then Cr. The Cb and Cr order is different.
Shanmukh.SS
