ippirotate in ipp 9.0
steffenroeber
i'm trying to migrate to 9.0. I found that ippirotate isno longer available and I found an article how to roate using warping functions. But that does not work. I want to rotate around the image center and the destination image resize is enlarged to show the whole rotated image:
IppiSize srcSize = { i_src.getWidth(), i_src.getHeight() };
  IppiRect srcRect = { 0, 0, i_src.getWidth(), i_src.getHeight() };
  float64 coeffs[2][3];
  float64 bound[2][2];
  float64 shiftX;
  float64 shiftY;
  auto status = ippiGetRotateShift(srcSize.width / 2, srcSize.height / 2, degrees, &shiftX, &shiftY);
  status = ippiGetRotateTransform(degrees, -shiftX, shiftY, coeffs);
  status = ippiGetAffineBound(srcRect, bound, coeffs);
  IppiSize dstSize = { bound[1][0] - bound[0][0] + 1, bound[1][1] - bound[0][1] + 1 };
  cImg dstImg(i_src.getImgType().getTypeId(), dstSize.width, dstSize.height);
  sint32 specSize = 0;
  sint32 bufferSize = 0;
  float64 borderValue[] = { 0 };
  status = ippiWarpAffineGetSize(srcSize, dstSize, ipp8u, coeffs, ippLinear, ippWarpForward, ippBorderConst, &specSize, &bufferSize);
  IppiWarpSpec *spec = reinterpret_cast<IppiWarpSpec *>(ippsMalloc_8u(specSize));
  status = ippiWarpAffineLinearInit(srcSize, dstSize, ipp8u, coeffs, ippWarpForward, 1, ippBorderConst, borderValue, 0, spec);
  m_buffer.resize(bufferSize);
  IppiPoint dstOffset = { 0, 0 };
  status = ippiWarpAffineLinear_8u_C1R(i_src.getPixel<uint8>(0, 0), i_src.getYPitch(),
                                       dstImg.getPixel<uint8>(0, 0), dstImg.getYPitch(), dstOffset, dstSize, spec, m_buffer.data());
But the resulting image is wlays slightly outside the image boundaries.
Chao_Y_Intel
I attached an rotate example with Affine,   could you have have if it works for your?
Chao
steffenroeber
your example is very similar to my code. But how do you compute the correct shiftX and shiftY values?
Jonghak_K_Intel
Hi steffenroeber,
Please check here https://software.intel.com/en-us/node/504405 for ippiGetRotateShift that computes shift values for rotation.
Thank you
steffenroeber
The ippiGetRotateShift only helps, if the destination image has same size as sozrce. Finally I found another solution:
ippiGetRotateTransform(angle, 0, 0, coeffs);
dstSize.width = bound[1][0] - bound[0][0] + 1;
dstSize.height = bound[1][1] - bound[0][1] + 1;
coeffs[0][2] = -bound[0][0];
coeffs[1][2] = -bound[0][1];
