ipprWarpAffine bug
Ken_Thornton
I'm running tests on ipprWarpAffine and get failures for certain permutation matrices.
My IPP build is 58644 (April 6, 2018). I'm running on Windows 7 (Intel Core i7) and using the ia32_win IPP libraries.
Below is a simple example to illustrate the problem.
void TestWarpAffine()
	double coefs[3][4] ={{0.0, 0.0, 1.0, 0.0}, {1.0, 0.0, 0.0, 0.0}, {0.0, 1.0, 0.0, 0.0}};
	unsigned char in[27] ={0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26};
	unsigned char out[27] ={0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
	IpprVolume srcSize ={3,3,3}, dstSize ={3,3,3};
	IpprCuboid srcVOI ={0,0,0,3,3,3}, dstVOI ={0,0,0,3,3,3};
	//Step 1: Allocate buffer
	int nBufferSize = 0;
	IppStatus sts = ipprWarpAffineGetBufSize(srcSize, srcVOI, dstVOI, coefs, 1, ippLinear, &nBufferSize); //1 means 1 channel
	ASSERT(sts == ippStsOk && nBufferSize >= 0);
	nBufferSize = __max(nBufferSize, 10); //Protect against allocating 0 bytes
	Ipp8u* pBuffer = ippsMalloc_8u(nBufferSize);
	ASSERT(pBuffer != NULL);
	//Step 2: Warp
	sts = ipprWarpAffine_8u_C1V(in, srcSize, 3, 9, srcVOI, out, 3, 9, dstVOI, coefs, ippLinear, pBuffer); //3 bytes between rows, 9 bytes between planes
	ippsFree(pBuffer);
	ASSERT(sts == ippStsOk); //Will get sts == -56
	const IppLibraryVersion* pVer = ippGetLibVersion();
Gennady_F_Intel
is that 64 or 32 bit code or both?
Gennady_F_Intel
-56 error code means that ippStsCoeffErr          determinant of the transform matrix Aij is equal to zero. if you will fix this - your case will work.
Ken_Thornton
Gennady,
No the determinant is 1, not 0. So it is invertible.
If p is a 3D point in the source volume and q is a 3D point in the destination volume:
      | 0 0 1 |       | 0 |
q = | 1 0 0 | p + | 0 |
      | 0 1 0 |       | 0 |
The inverse transformation is:
       | 0 1 0 |
p =  | 0 0 1 | q
       | 1 0 0 |
                                       -1
            | 0 1 0 |      | 0 0 1 |
Since   | 0 0 1 |  =  | 1 0 0 |
            | 1 0 0 |      | 0 1 0 |
Gennady_F_Intel
Ken, we confirmed the problem and will add the fix into one of the nearest updates. We will keep you updated with the status of this issue. Thanks for report.
Gennady_F_Intel
the fix of the problem available since IPP 2019 u1 and the latest 2020 versions as well.
