ippsAddProduct low precision
janw80
Hi! On Intel IPP 6.1.2.051 on Xeon E5430 (EM64T, SSE4.1) the result of ippsAddProduct_32fc has for some reason an error of the order of +-1e-7 when compared to Matlab, ippsMul_32fc with ippsAdd_32fc_I, and direct C 32bit arithmetic as well as 64bit arithmetic that is cast to 32bit at the end. All the comparison answers are identical, only the ippsAddProduct answer is different.
Is that a bug in IPP? Or is this to be expected (SSE4.1 DPPS instruction known to do something odd on Xeon?)
Reference (cast): 39359.343750000000000 + i*0.0
Reference (float): 39359.343750000000000 + i*0.0
ippsAddProduct: 39359.347656250000000 + i*0.000000000000000
ippsMul, ippsAdd_I: 39359.343750000000000 + i*0.000000000000000
The code is:
[cpp]#include
#include
#define ACCU_RE  3.653725000000000e+04
#define A_B_RE   3.360162734985352e+01
#define A_B_IM   4.114639663696289e+01
int main(int argc, char** argv) {
   const int N = 16;
   Ipp32fc v;
   Ipp32fc* a = ippsMalloc_32fc(N);
   Ipp32fc* b = ippsMalloc_32fc(N);
   Ipp32fc* accu_fma = ippsMalloc_32fc(N);
   Ipp32fc* accu_muladd = ippsMalloc_32fc(N);
   Ipp32fc* tmp = ippsMalloc_32fc(N);
   v.re = ACCU_RE;
   v.im = 0;
   ippsSet_32fc(v, accu_fma, N);
   ippsSet_32fc(v, accu_muladd, N);
   v.re = A_B_RE;
   v.im = A_B_IM;
   ippsSet_32fc(v, a, N);
   v.re = A_B_RE;
   v.im = -A_B_IM;
   ippsSet_32fc(v, b, N);
   double ref = ACCU_RE + (A_B_RE*A_B_RE + A_B_IM*A_B_IM);
   float  refF = float(ACCU_RE) + (float(A_B_RE)*float(A_B_RE) + float(A_B_IM)*float(A_B_IM));
   ippsAddProduct_32fc(a, b, accu_fma, N);
   ippsMul_32fc(a, b, tmp, N);
   ippsAdd_32fc_I(tmp, accu_muladd, N);
   printf("Reference (cast):   %6.15f + i*0.0\n", float(ref));
   printf("Reference (float):  %6.15f + i*0.0\n", refF);
   printf("ippsAddProduct:     %6.15f + i*%6.15f\n", accu_fma[0].re, accu_fma[0].im);
   printf("ippsMul, ippsAdd_I: %6.15f + i*%6.15f\n", accu_muladd[0].re, accu_muladd[0].im);
   return 0;
[/cpp]
Chao_Y_Intel
For single precision float point data, it only 23 bit ( 1e-7) for the data.
http://en.wikipedia.org/wiki/IEEE_754-1985
so, it is fine if you have data precision around 1e-7. If you want to have more high precision, you can use double precision for the computation.
Chao
janw80
Thanks for the numerical info!
Still, with identical inputs having zero imaginary parts, the full-double c=a*b+c with the result converted to single, and full-single c=a*b+c both give the same result.
So I'm not sure how full-single ippsAddProduct_32fc can give a result different from full-single c=a*b+c.
SergeyKostrov
Valued Contributor II
That is possible when binary representations of results in IEEE 754 for single- and double-precision floatsare identical.
Here is an opposite case:
16968003(Base10) = 0x4B8174A2(Base16) => 0 10010111 00000010111010010100010(Base2\IEEE754)
16968004(Base10) = 0x4B8174A2(Base16) => 0 10010111 00000010111010010100010(Base2\IEEE754)
16968005(Base10) = 0x4B8174A2(Base16) => 0 10010111 00000010111010010100010(Base2\IEEE754)
A precision loss happened because source numbers are greater than 2^24.
