6847 Discussions
libiomp5.so: undefined reference to 'pthread_atfork' compiling openssl on intel64/emt64
Nick_Lindberg
I am attempting to compile openssl using the patch to allow the openssl functions to link against the special crypto functions in ipp (so that I can leverage the built in AES instructions on my Westmere chip.) I've been following the guide here:
http://software.intel.com/en-us/articles/boosting-openssl-aes-encryption-with-intel-ipp/
Everything is working great except that when I try to compile after patching openssl, at the step:
./build_ssl_ipp_sh. openssl-0.9.8j linuxemt64
I get the the following error:
ar: creating ../libssl.a
/opt/intel/Compiler/11.1/072/lib/intel64/libiomp5.so: undefined reference to `pthread_atfork'
collect2: ld returned 1 exit status
make[2]: *** [link_app.gnu] Error 1
make[1]: *** [openssl] Error 2
make: *** [build_apps] Error 1
make[1]: *** [bntest] Error 2
make: *** [tests] Error 2
I've gone through the makefiles and tried changing -lpthread to -pthread, but that didn't solve the problem. Any help? I'm using the ipp that came with my Linux Intel Professional C++ Compiler Suite 11.1. Here is my $LD_LIBRARY_PATH:
/opt/intel/Compiler/11.1/072/lib/intel64:/opt/intel/Compiler/11.1/072/ipp/em64t/sharedlib:/opt/intel/Compiler/11.1/072/mkl/lib/em64t:/opt/intel/Compiler/11.1/072/tbb/intel64/cc4.1.0_libc2.4_kernel2.6.16.21/lib:/lib64
I've installed everything using the steps in the aforementioned link. Doing a search on this error, I see that others have run into the same problem-- though usually it is solved by adding -lpthread. What I'm wondering is if I have to add it anywhere else in the make process, but I can't figure out where because it's part of $LIBRARIES that seems to get pulled into everything for linking.
The closest I found to a solution is:
http://software.intel.com/en-us/articles/how-to-build-ipp-application-in-linux-environment/
but that didn't shed any light. I've confirmed that /lib64 indeed contains:
libpthread-2.9.so
libpthread.so.0
Do I need a newer version of libpthread?
Thanks, any help would be greatly appreciated.
NDL
Ying_H_Intel
Hi NDL,
The version of libpthreadshould benot problem. Mineare even lower than your's:
libpthread-2.5.so libpthread.so.0
Could you please go through the makefile to see if there are some place where -lpthreadis before -liomp5?
I mean
for example,it will getundefined reference to `pthread_atfork', if the command line is like
>g++ main.cpp -omain -ldl -lpthread -L/opt/intel/ipp/lib/intel64 -lipps -lippcore -L/opt/intel/composerxe-2011.1.036/compiler/lib/intel64 -liomp5
fix it by
>g++ main.cpp -omain -ldl -L/opt/intel/ipp/lib/intel64 -lipps -lippcore -L/opt/intel/composerxe-2011.1.036/compiler/lib/intel64 -liomp5 -lpthread
Ying
Nick_Lindberg
Ying,
Yes, I've checked for that-- I will go double check again!
Thanks for your response--
NDL
