looking for PseudoInverse function
sagent2
Hello Dears
I'm engineer of small company. I'm using IPP for Matrix analysis. because IPP is faster and convinient than other lib.
I'm looking for PseudoInverse function. but I couldn't find it.
if not. does anyone use pseudoinverse in IPP? I want to how implement the process
Vladimir_Dudnik
just to be clear, what do you mean under pseudo inverse operation?
Vladimir
sagent2
Vladimir
Thanks for reply
Sorry for my stupid english skill :)
Question 1: Does IPP have a pseudo inverse function?
Question 2: If doesn't exist in IPP, How operate pseudo inverse using IPP?
Regards, sagent2
Ying_H_Intel
Quoting - sagent2
Thanks for reply
Regards, sagent2
Hi Sagent2,
Are you looking for the function like matlab discription,
PINV(A) produces a matrix X of the same dimensions
as A' so that A*X*A = A, X*A*X = X and A*X and X*A
are Hermitian. The computation is based on SVD(A) and any
singular values less than a tolerance are treated as zero.
The default tolerance is MAX(SIZE(A)) * NORM(A) * EPS(class(A)).
right?
Then IPP haven't direct function, but ipp should be have oneSVD function, you may check it in ippm or ipps manual. Or check IPP's sister library, math kernal library (MKL), which provide more math routines in it.
Ying
