missing LIBs of IPP in Parallel Studio XE 2015
Ralf_K_
i'm trying to compile some IPP code (IPP_SEQUENTIAL_STATIC)
but the linker is missing some libs like
ippjmt.lib
Where can i find them?
Is IPP 8.2 complete delivered with XE 2015?
(I use XE 2015 in Testmode)
Ralf
Sergey_K_Intel
Hi Ralf,
Now the IPPJ library along with some other libs are not installed by default together with IPPCORE, IPPS, IPPI and rest of main IPP libraries.
You need to start installation process of IPP or PS XE 2015 again (in "Modify" mode), press "Customize" button on some of IPP-related installation dialogs and set checkboxes on additional IPP libraries you need.
Ralf_K_
Hi Sergey,
solved.
Thanks for you support!
Best regards
Ralf
