mp4 muxer supports VBR ?
mb701
I would like to use the mp4 muxer from the IPP samples, but on the readme.htm it says:
Known Limitations
  • Streams encoded with variable bit rate (VBR) are not supported in current version.
I was able to mux a h.264 variable bit rate video stream to the MP4 muxer and view it via vlc/wmp. Is this limitation in IPP V6 still valid ? Or can someone explain what this limitation means in this case ?
I used the H.264 encoder from IPP and set the following parameters:
Params.info.clip_info.height=imgHeight; Params.info.clip_info.width=imgWidth;
//Params.info.bitrate = 1000000;
Params.rate_controls.method = UMC::H264_Rate_Control_Method::H264_RCM_QUANT;
Params.rate_controls.quantI = 21;
Params.rate_controls.quantP = 21;
Params.rate_controls.quantB = 21;
Params.numThreads = 1;
if((status = H264Encoder.Init(&Params))!=UMC::UMC_OK)
Thanks for any help !
Best regards
mb701
Pavel_V_Intel
Good day.
This readme file is probably out of date. MP4Muxer can mux VBR streams.
This is not VBR, this is constant quantization without rate control. For VBR encoding you need to use H264_RCM_VBR.
Not applicable
