mpeg4_enc sample could not pass building
guestb
hi
I have try to build mpeg4_enc sample.
But error .
error 1 fatal error C1083: could not open file:ippdefs.h: No such file or directory d:\Intel\w_ipp-samples_p_6.1.0.038\ipp-samples\audio-video-codecs\codec\mpeg4_enc\include\mp4_enc_bitstream.hpp 13 mpeg4_enc
I have searched my computer, not find the file ippdefs.h
How should I do?
Chao_Y_Intel
Have you installed Intel IPP libraries? It is a separated package from Intel IPP sample code.
After installation, it will be located at the folder by default:
C:Program FilesIntelIPPx.x.x.xxx(version number)ia32include
Before building the sample code, it also needs to set IPPROOT environment variable, and install DirectX 9 SDK first. You can check ReleaseNotes.htm at audio-video-codecs folder for more information on building steps.
Chao
jon_shadforth
Quoting - guestb
hi
But error .
error 1 fatal error C1083: could not open file:ippdefs.h: No such file or directory d:Intelw_ipp-samples_p_6.1.0.038ipp-samplesaudio-video-codecscodecmpeg4_encincludemp4_enc_bitstream.hpp 13 mpeg4_enc
How should I do?
Where did you install IPP? For example, on my machine the installation is in:
C:Program FilesIntelIPP5.3.3.082ia32
... and my include files are in:
C:Program FilesIntelIPP5.3.3.082ia32include
ippdefs is in the above directory.
Also - which build batch file are you using. On my machine I ran build32.bat in the audio-video-codecs sample folder to build everything. (This worked fine after I'd edited directx_sdk.bat to setup for my particular version of direct x).
jon
Chao_Y_Intel
Jon,
IPP sample code version is 6.1, and IPP library is 5.3.
These versions need to be matched. You can download IPP 6.1 from:
https://registrationcenter.intel.com
Chao
guestb
Quoting - Chao Yu (Intel)
Chao
guestb
Jon,
Chao
I do not find IPP library 6.1?
Can you please paste the code?
Chao_Y_Intel
Quoting - guestb
IPP 6.1 package is more than 250M. It can be downloaded from registration center:
go the website: https://registrationcenter.intel.com/
Select "Register users login"
Use your user/password" to login into the website. (If you do not have a license, you can also apply for eval licensee for evaluation purpose).
After login, you can select "Intel Integrated Performance Primitives for Windows*" to download the package.
Chao
