simple_player can't add video render
iambaeba1
Dear support
I got the IPP 6.0 evalution. and complie the simple_player project.
I execute the simple_player.exe followed command.
c:>simple_player.exe -v dx sd.mpg
Audio Render : DSOUND
Video Render : NULL
-RenderFormat: YV12
Stream Type : MPEG2T
Video Info :
-Video Type : MPEG2
-Resolution : 720x480
-Frame Rate : 29.97
Audio Info :
-Audio Type : AC3
-S.Frequency : 48000
-Num.Channel : 2
-BitPerSample: 16
DecRate:740.44 fps(Dec 1.08ms/f + Conv 0.28ms/f = 1.35ms/f) RndrRate 30.12fps Audio Dec 364.55chnls
DecRate:1144.41 fps(Dec 0.71ms/f + Conv 0.16ms/f = 0.87ms/f) RndrRate 29.97fps Audio Dec 413.30chnls
DecRate:1203.44 fps(Dec 0.67ms/f + Conv 0.16ms/f = 0.83ms/f) RndrRate 30.11fps Audio Dec 425.18chnls
Audio render is good..
But video render is not added to simple_player.
-v fw, fwf option is good. others is not ignored..( -v gdi, -v dx -v blt)
Thank you
Bae
ps : If simple_player is executed, can I see the decoded frames of movie in windows ?
ps : Using IPP 5.3's, I can see the decoded video frame in simple_player.
But only -v gdi option can produce correct display.. others -v option can't produce.
ps : my environment is followed
. I first installed IPP 5.3
. I installed Microstudio 2008.
. I installed IPP 6.0.2.074 evaluation
. I complied simple_player.exe
And OS is WinXP. and CPU is Core2 Duo T9400 2.53GHz, 4GB RAM.
ps : video information is followed
General
Complete name : D:\sd.mpg
Format : MPEG-TS
File size : 168 MiB
Duration : 3mn 41s
Overall bit rate : 6 387 Kbps
Video
Menu ID : 3470 (0xD8E)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, Matrix : Default
Duration : 3mn 41s
Bit rate mode : Constant
Bit rate : 5 941 Kbps
Nominal bit rate : 6 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 29.970 fps
Standard : NTSC
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.574
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 3mn 41s
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Video delay : -32ms
Vladimir_Dudnik
did you try to run simple_player with default parameters (not specifying a particular video render)?
Vladimir
iambaeba1
Vladimir
Dear Vladmir
I checked the source code for IPP 6.0 samples (simpler_player project)
I found that simple_player can't support -v blt, gdi, blt. -_-
You may check the source code in ipp-samplesaudio-video-codecscoreumcincludeumc_defs.h
Video rederers are defined only two mode.
// video renderers
#define UMC_ENABLE_DX_VIDEO_RENDER
#define UMC_ENABLE_FW_VIDEO_RENDER
In IPP 5.3 version, video renderers has 4 modes
// video renderers
#define UMC_ENABLE_BLT_VIDEO_RENDER
#define UMC_ENABLE_GDI_VIDEO_RENDER
And IPP 6.0's simple_player's source code has a problem calling DirectX modules.
In ipp-samplesaudio-video-codecsiovideo_renderssrcdx_drv.cpp, line 263 code occurs errors
/* Trying to create max_b, max_b-1, ..., min_b overlays. */
for (bufs_num = max_b; bufs_num >= min_b; --bufs_num)
ddsdOverlay.dwBackBufferCount = bufs_num;
hRes = drv->dd_obj->CreateSurface(&ddsdOverlay, &drv->dd_srf_front, NULL); // line 263
if (SUCCEEDED(hRes))
break;
the error code is 0x88760091.
I have only called "simpler_player -v dx d:sd.mpg".
I don't know the directX calling fail.
Bae
Chao_Y_Intel
Bae,
The DX render is supported in the current release. gdi and bltrenders weresupported inold releases.Our new releasehas removed them. Can DX render be used there?
Chao
iambaeba1
Quoting - Chao Yu (Intel)
Bae,
Chao
Dear Chao
I have tested all of combination of simple_player's parameters.
for directx displaying, the following options are success
-v dx -f rgb565
-v dx -f yuy2
other options can't display the screen.
I have debugged the sample source code becacuse simple_player can't display the screen.
video_reders's project's dx_drv.cpp/dx_drv.h include the followed code.
const DDPIXELFORMAT umc_dx_overlay_formats[] =
{sizeof(DDPIXELFORMAT), DDPF_FOURCC | DDPF_YUV, MAKEFOURCC('Y','V','1','2'), 12, 0, 0, 0, 0}, /* YV12 */
{sizeof(DDPIXELFORMAT), DDPF_FOURCC | DDPF_YUV, MAKEFOURCC('Y','U','Y','2'), 16, 0, 0, 0, 0}, /* YUY2 */
{sizeof(DDPIXELFORMAT), DDPF_FOURCC | DDPF_YUV, MAKEFOURCC('U','Y','V','Y'), 16, 0, 0, 0, 0}, /* UYVY */
{sizeof(DDPIXELFORMAT), DDPF_FOURCC | DDPF_YUV, MAKEFOURCC('N','V','1','2'), 12, 0, 0, 0, 0}, /* NV12 */
{sizeof(DDPIXELFORMAT), DDPF_RGB, 0, 16, 0xf800, 0x07e0, 0x001f, 0} /* RGB565 */
typedef enum DDVideoDrvColorFormat
DXVideoDrv_YV12 = 0,
DXVideoDrv_YUY2 = 1,
DXVideoDrv_UYVY = 2,
DXVideoDrv_NV12 = 3,
DXVideoDrv_RGB565 = 4
} DDVideoDrvColorFormat;
simple_player's option have yv12, yuv420, yuv422, yuy2, rgb565, rgb24.
But the original source code support yu12, yu2, uyvy, nv12, rgb565.
And I don't know the reason that other pixel fomat option can't display the screen.
(I'm begginer for directX mechanism...^^;;;)
Bae
yosepho
I am also having trouble rendering simple player to the screen.
C:Program FilesIntelIPP6.0.0.062ia32ipp-samplesaudio-video-codecs_binWi
n32release>simple_player.exe -v fw -f yuy2 M:VideoImagingTesterH.264Test_Seq
uence480_200_25_HQ.mp4
Usage: ????????e??w???2?????????????????????????????4????????????????????????
[-s(ilent)]
[-b(lind)]
[-n(atural temp)]
[-u(nrendered audio)
[-d(einterlacing)
[-i
[-t
[-p (must be in quotes if it contains gaps)]
[-v
-in the case of -vfwf>]
[-a
-in the case of -afwf]
[-f]
(-l |stream>(must be in quotes if it contains gaps)
What am I doing Wrong???
Joe
