.net developing Pre-sales advice
zhan_z_
I want to buy an Intel® Integrated Performance Primitives (Intel® IPP) for image processing.But my software is under .net framework.Does ipp support .net software?
And how? Are there some examples for me?
I try to make a c++ wrapper of ipp by CLR.But I falied.
Please help me to use it.
Best regard.
This is my wrapper by CLR:
#include "ipp.h"
#pragma comment(lib, "ippi.lib")
#pragma comment(lib, "ippcv.lib")
#pragma managed(pop)
using namespace System;
namespace IPPInterpolationWrapper {
    public ref class IPPInterpolation
    public:
        int x;
        int zzz;
        IppStatus ippiWarpAffine_16u_C1R1(const Ipp16u* pSrc,
            IppiSize srcSize,
            int srcStep,
            IppiRect srcROI,
            Ipp16u* pDst,
            int dstStep,
            IppiRect dstROI,
            double coeffs00,
            double coeffs01,
            double coeffs02,
            double coeffs10,
            double coeffs11,
            double coeffs12,
            int interpolation);
IppStatus IPPInterpolationWrapper::IPPInterpolation::ippiWarpAffine_16u_C1R1(const Ipp16u* pSrc,
    IppiSize srcSize,
    int srcStep,
    IppiRect srcROI,
    Ipp16u* pDst,
    int dstStep,
    IppiRect dstROI,
    double coeffs00,
    double coeffs01,
    double coeffs02,
    double coeffs10,
    double coeffs11,
    double coeffs12,
    int interpolation)
    IppiWarpSpec* pSpec = 0;
    Ipp8u* pInitBuf = 0;
    int specSize = 0, initSize = 0, bufSize = 0; Ipp8u* pBuffer = 0;
    const Ipp32u numChannels = 1;  //此参数修改通道数
    IppiPoint dstOffset = { 0, 0 };
    IppStatus status = ippStsNoErr;
    IppiBorderType borderType = ippBorderTransp;
    IppiWarpDirection direction = ippWarpForward;
    IppiSize dstRoiSize = { dstROI.width, dstROI.height };
    double cf[2][3];
    IppiSize srcRoiSize;
    Ipp16u* pSrcRoi = (Ipp16u*)((Ipp8u*)pSrc + srcROI.y * srcStep) + srcROI.x *
        numChannels;
    Ipp16u* pDstRoi = (Ipp16u*)((Ipp8u*)pDst + dstROI.y * dstStep) + dstROI.x *
        numChannels;
    IppiInterpolationType interp;
    int borderSize = 0;
    Ipp64f valB = 0.0, valC = 0.5; /* Catmull-Rom filter */
    if (srcROI.x < 0 || srcROI.y < 0 || srcROI.x >= srcSize.width || srcROI.y >=
        srcSize.height)
        return ippStsRectErr;
    if (dstROI.x < 0 || dstROI.y < 0)
    /* Clip the source roi */
    if (srcROI.x + srcROI.width > srcSize.width) srcROI.width = srcSize.width -
        srcROI.x;
    if (srcROI.y + srcROI.height > srcSize.height) srcROI.height = srcSize.height -
        srcROI.y;
    srcRoiSize.width = srcROI.width;
    srcRoiSize.height = srcROI.height;
    switch (interpolation)
    case IPPI_INTER_NN:
        interp = ippNearest;
        break;
    case IPPI_INTER_LINEAR:
        interp = ippLinear;
        break;
    case IPPI_INTER_CUBIC:
        interp = ippCubic;
        borderSize = 1;
        break;
    default:
        return ippStsInterpolationErr;
    /* compute new coefficients with taking into account ROI offsets*/
    cf[0][0] = coeffs00; cf[0][1] = coeffs01; cf[0][2] = coeffs02 +
        coeffs00 * srcROI.x + coeffs01 * srcROI.y - dstROI.x;
    cf[1][0] = coeffs10; cf[1][1] = coeffs11; cf[1][2] = coeffs12 +
        coeffs10 * srcROI.x + coeffs11 * srcROI.y - dstROI.y;
    /* define border type depending on the source ROI */
    if (srcROI.x >= borderSize) borderType = (IppiBorderType)(borderType |
        ippBorderInMemLeft);
    if (srcROI.y >= borderSize) borderType = (IppiBorderType)(borderType |
        ippBorderInMemTop);
    if (srcROI.x + srcROI.width <= srcSize.width - borderSize) borderType =
        (IppiBorderType)(borderType | ippBorderInMemRight);
    if (srcROI.y + srcROI.height <= srcSize.height - borderSize) borderType =
        (IppiBorderType)(borderType | ippBorderInMemBottom);
    /* Spec and init buffer sizes */
    status = ippiWarpAffineGetSize(srcRoiSize, dstRoiSize, ipp16u, cf, interp, direction,
        borderType, &specSize, &initSize);
    if (status < ippStsNoErr) return status;
    /* Memory allocation */
    pSpec = (IppiWarpSpec*)ippsMalloc_8u(specSize);
    if (pSpec == nullptr)
        return ippStsNoMemErr;
    pInitBuf = ippsMalloc_8u(initSize);
    if (pInitBuf == nullptr)
        ippsFree(pSpec);
    /* Filter initialization */
    case IPPI_INTER_NN:
        status = ippiWarpAffineNearestInit(srcRoiSize, dstRoiSize, ipp16u, cf, direction,
            numChannels, borderType, 0, 0, pSpec);
        break;
        status = ippiWarpAffineLinearInit(srcRoiSize, dstRoiSize, ipp16u, cf, direction,
        break;
        status = ippiWarpAffineCubicInit(srcRoiSize, dstRoiSize, ipp16u, cf, direction,
            numChannels, valB, valC, borderType, 0, 0, pSpec, pInitBuf);
        break;
    ippsFree(pInitBuf);
        ippsFree(pSpec);
        return status;
    /* work buffer size */
    status = ippiWarpGetBufferSize(pSpec, dstRoiSize, &bufSize);
        ippsFree(pSpec);
        return status;
    pBuffer = ippsMalloc_8u(bufSize);
    if (pBuffer == nullptr)
        ippsFree(pSpec);
    /* Warp processing */
    case IPPI_INTER_NN:
        status = ippiWarpAffineNearest_16u_C1R(pSrcRoi, srcStep, pDstRoi, dstStep,
            dstOffset, dstRoiSize, pSpec, pBuffer);
        break;
        status = ippiWarpAffineLinear_16u_C1R(pSrcRoi, srcStep, pDstRoi, dstStep,
        break;
        status = ippiWarpAffineCubic_16u_C1R(pSrcRoi, srcStep, pDstRoi, dstStep,
        break;
    ippsFree(pSpec);
    ippsFree(pBuffer);
    return status;
SergeyKostrov
Valued Contributor II
>>...I try to make a c++ wrapper of ipp by CLR.But I falied... What was an error? Did you check dependencies of your test application with MS Depends utility? Take into account that it could be a simple DLL dependency issue since some IPP's DLLs loaded at run-time and MS Depends utility doesn't show these "waterfall" DLLs.
SergeyKostrov
Jing_Xu
How failed? Any error messages?
zhan_z_
Thank you very much! Under your advise  I just change the linking type as "Single-threaded static Library". Now this DLL can run well. But I can't get the desired result.I'm using ippiWarpAffineLinear_16u_C1R to do Affine Transform.
int srcStep = ((srcBitsPerPixel * srcWidth) + 31) / 32 * 4;
int dstStep = ((srcBitsPerPixel * dstWidth) + 31) / 32 * 4;
IppiPoint dstOffset;
dstOffset.x = 0;
dstOffset.y = 0;
IppiSize dstRoiSize;
dstRoiSize.width = srcWidth;
dstRoiSize.height = srcHeight;
int bufSize = 0;
Ipp8u* pBuffer;
int status = ippiWarpGetBufferSize(pSpec, dstRoiSize, &bufSize); //this line error, with a status -8. Which means a null pointer.
ippsFree(pSpec);
return status;
ippsFree(pSpec);
// Warp proce
status = ippiWarpAffineLinear_16u_C1R((Ipp16u *)pSrcPixelData, srcStep, (Ipp16u *)pDstPixelData, dstStep,
zhan_z_
I just post a new problem to describe my problems.Could you pay attention to it.? Link:https://software.intel.com/en-us/forums/intel-integrated-performance-primitives/topic/737380
