printf_32f error
Knoght
I'm trying to use IPP (eval for 30 days).
I used this example for FFT:
Ipp32f x[8], X[10];
int n;
IppStatus status;
IppsFFTSpec_R_32f* spec;
status = ippsFFTInitAlloc_R_32f (&spec, 3, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone);
for (n=0; n<8; ++n) x = (float)cos(IPP_2PI *n *16/64);
status = ippsFFTFwd_RToCCS_32f (x, X, spec, NULL);
ippsMagnitude_32fc ((Ipp32fc*)X, x, 4);
ippsFFTFree_R_32f (spec);
printf_32f("fft magn=", x, 4, status);
return status;
All is ok if I comment "printf_32f(...)". I haven't used this function since now, but i can't find anything about on the net. I'm using an i7-720QM so I'm using "IPP for Intel 64 Architecture", I've linked all possible .lib but "printf_32f(...) is a "unrecognised symbol".
What's my mistake?
Thanks and sorry for my bad english :)
Vladimir_Dudnik
It seems you copied that piece of code from documentation? Obviously printf_32f is some wrapper on top of usual C run time printf functions which output to console floating point values. The realization of that should be somewhere in documentation from where you copied the code
You also can substitute that call with your realization which may output to console array of FP values.
Vladimir
Vladimir_Dudnik
Vladimir
Knoght
You are right, I've copied the code from documentation. I suppose printf_32f() was on library, now I'm looking for it in documentation. Thank to give me an indication, for me it's very important because I'm alone here :P
If I can't find, I'll tell you. Can I?
Thank you Vladimir.
Vladimir_Dudnik
Sure! That's why we maintain that forum isn't it?
BTW, if there is no that function in documentation (by mistake for example) you can use any technique you know to dump array of FP values to console.
Vladimir
Knoght
Yep, all ok here. I made a realization of printf_32f and works fine. It's the proof that I was in panic :) (29 days left) :P
Thank you again :)
Vladimir_Dudnik
Do not be in panic with 30 day evaluation period. There is no time bomb in IPP, it still be fully functional out of evaluation period. During30 days evaluation you will have technical support and you may contactIntel Premier Supportchannel in case you need longer evaluation period
Vladimir
