problem in ippiSample
Intel_C_Intel
In the ippiSample example program images are displayed upside-down. You can easily verify this by replacing the Jaehne image with a non symmetrical one.
How can I modify the example to display images correctly. Thank you
Vladimir_Dudnik
you can change drawing by modifying CSampleView::OnDraw() function in SampleView.cpp file.
Vladimir
Intel_C_Intel
I was running the program on an extended desktop over two monitors (2560x1024); in that case images were upside down. When I use a single 1280*1024 desktop everything is OK.
Best regards
Ciro
Vladimir_Dudnik
Oh, really? That's interesting. Probably it is connected with setting for the second monitor?
Vladimir
