6845 Discussions
problem linking under ipp5.3 update2 when using function ippGetCpuFreqmhz
Bill_B_
I have upgraded to ipp5.3 update 2 from ipp5.2. I try to compile my source using the Intel compiler in the same way but the linker now throws the error:
ippcorel.lib(ippcpufreq.obj) : error LNK2001: unresolved external symbol __time64
I am using other core library functions, and my source compiles and links fine if I comment out:
ippGetCpuFreqMhz(pInt);
It compiles and links with that function using ipp versions 5.2 and earlier.
Vladimir_Dudnik
it is known issue, reported against MSVC 6.0 and VC2003. They do not provide _time64 functions in C run-time libraries. You may migrate to VC2005 otherwise you should not call ippGetCpuFreq function.
Vladimir
bill-brinson
Thanks for the information. I am compiling from the Intel IA-32 command line. I do have MSVC6 and MS Platform SDK for Windows Server 2003 SP1 installed. I was wondering why I can compile and link with IPP 5.2 and previous versions when using ippGetCpuFreq. Was there a change in IPP 5.3 (I'm using update 2) related to _time64?
Thanks again,
Bill
Vladimir_Dudnik
Bill,
the change is that IPP 5.3 was compiled with support for vc2005 CRT. Although we minimaze the use ofCRT functions in IPP,we still needed in malloc/free and time64 calls
Vladimir
bill-brinson
Thanks Vladimir,
That clears that issue up. In currently in the process of installing the MSVC2005 redistributable runtime.
Bill
Vladimir_Dudnik
I'm affraid that will not be enough. Redistributable run-time help for run-time issues, but will not help MSVC 6.0 or vc2003. They link the old libraries which do not have _time64 function.
Vladimir
bill-brinson
Hi Vladimir,
I'm downloading VC2005 Express and MS SDK 2008. My connection is rather slow so it looks like I'll be rebuilding my apps tomorrow.
Bill
Vladimir_Dudnik
I think it should be enough to have vc2005 express to solve that issue. You may need SDK only if your application use something not availbale in VC Express edition (like MFC)
Vladimir
bill-brinson
I installed VC2005 express and I now get a bunch of compiler errors related to the xutility file in .Microsoft Visual Studio 8VCINCLUDE. I don't get any other errors. I few Google searches have turned up nothing other than verifying that the -Qvc8 flag is used in the icl.cfg file. I can compile my EM64T versions of my code with no errors (using MS PSDK 2003 Server R2). I just get the xutility errors when compiling IA-32 versions. Any insights?
Bill
