problem with AMRWB codec
george_miller
my general processis to convert a g711 file to aamrwb file. i decode a certain number of g711 frames into pcm, convert these frames to 16000 sampling rate (using ippsFIR64f_16s_Sfs), and then encode these frames into amrwb codec. Since i dont have anyway to listen to this file, i then convert this back to g711 doing basically the reverse, include converting back to 8000 sampling rate. unfortunately, this g711 file plays, but there is a small amount of static in the background. Any ideas? This happens also with G722.1
i have used ipp many years for other codecsbut have never used a codec whose sampling rate was 16000. is the ippsFIR64f_16s_Sfs routine the correct way to do this conversion?
Chao_Y_Intel
The problem came from ippsFIRMR function. For those who want to use the ippsFIRMR function, the following are two simple examples:
upsampling()
IppsFIRState32f_16s *pState;
Ipp32f pTaps[2] = { 1.0,1.0};
int tapsLen = 2;
int upFactor = 2;
int upPhase = 0;
int downFactor =1;
int downPhase = 0;
Ipp16s *pDlyLine = NULL;
Ipp16s pSrc = { 1,2,3,4,5,6,7};
Ipp16s pDst[14] ;
int numIters = n;
IppStatus status;
status = ippsFIRMRInitAlloc32f_16s( &pState, pTaps, tapsLen, upFactor, upPhase,
downFactor, downPhase, pDlyLine);
if( ippStsNoErr != status) return -1;
status = ippsFIR32f_16s_Sfs( pSrc, pDst, numIters, pState,0);
status = ippsFIRFree32f_16s( pState );
downsampling()
Ipp32f pTaps[1] = { 1.0};
int tapsLen = 1;
int upFactor = 1;
int upPhase = 0;
int downFactor =2;
int downPhase = 0;
Ipp16s pDst[4] ;
int numIters = n;
IppStatus status;
