problems with ippiFilterGauss_8u_AC4R
kolich
Hello.
I have such code:
IppStatus s;
LONG nWidth = 720;
LONG nHeight = 576;
BYTE* pImage = new BYTE[nWidth * nHeight * 4];
memset(pImage, 0, nWidth * nHeight * 4);
//really normal data is copied to pImage by memcpy
//but as example, i think, memset to 0 is OK
//Using Ipp8u & ippiMalloc_8u_AC4() gives the same result.
BYTE* pTemp = new BYTE[nWidth * nHeight * 4];
BYTE* pTemp1 = new BYTE[nWidth * nHeight * 4];
IppiSize roi;
roi.height = nHeight;
roi.width = nWidth;
s = ippiFilterGauss_8u_AC4R(pImage, nWidth * 4, pTemp, nWidth * 4, roi, ippMskSize3x3);
s = ippiFilterGauss_8u_AC4R(pTemp, nWidth * 4, pTemp1, nWidth * 4, roi, ippMskSize3x3);
after first ippiFilterGauss_8u_AC4R operation everything is OK, but on second ippiFilterGauss_8u_AC4R address access violation happens.
If i change nWidth & nHeight to 100 & 100 (value more less then 720) second operation works fine.
What's the problem?
Vladimir_Dudnik
Hi, below is answer from our expert, I hope it willhelp
ROI can't be equal image size. User has to provide data outside ROI. Correct usage can be seen from the example below:
#include "stdio.h"
#include
int main(void)
IppStatus s;
int nWidth = 720;
int nHeight = 576;
IppiSize roi;
Ipp8u *pImage, *pTemp, *pTemp1;
pImage = ippsMalloc_8u((nWidth+2) * (nHeight+2) * 4);
pTemp = ippsMalloc_8u((nWidth+2) * (nHeight+2) * 4);
pTemp1 = ippsMalloc_8u(nWidth * nHeight * 4);
memset(pTemp, 0, nWidth * nHeight * 4);
memset(pTemp1, 0, nWidth * nHeight * 4);
printf("memset - OK ");
//gives the same result.
roi.width = nWidth;
printf("pImage = %x, size = %x ", (int)pImage, nWidth * nHeight * 4 );
printf("pTemp = %x, size = %x ", (int)pTemp, nWidth * nHeight * 4 );
printf("pTemp1 = %x, size = %x ", (int)pTemp1, nWidth * nHeight * 4 );
s = ippiFilterGauss_8u_AC4R(pImage+nWidth*4+1, nWidth * 4, pTemp, nWidth * 4, roi, ippMskSize3x3);
printf("1-st Gauss - OK ");
s = ippiFilterGauss_8u_AC4R(pTemp+nWidth*4+1, nWidth * 4, pTemp1, nWidth * 4, roi, ippMskSize3x3);
printf("2-nd Gauss - OK ");
ippsFree(pImage);
ippsFree(pTemp);
ippsFree(pTemp1);
return 0;
Vladimir
