help me ! compile the g729 sample.
sendhb
hi verybody:
I download the speech sample. And compile the g729 sample. I use the encoder729i.exe to encoder a sample. It's PCM, 16bit, 8000Hz, 1ch, 128Kbps.The source file is 838,822 bytes. After encodering. The target file is 859,688 bytes. Why the target file is as almost long as source file.Can anybody help me .Thanks very much.
stray109
just see below codes:
static void encodedBitsUnPack_G729(
const char *bitstream, /* input bitstream */
short *bits, /* output: ITU bitstream unpacked format: 0 - BIT_0, 1 - BIT_1 */
int len
short i,j;
*bits++ = SYNC_WORD; /* bit[0], at receiver this bits indicates BFI */
if(len==10) *bits++ = SIZE_WORD; /* bit[1], to be compatible with hardware */
else if(len==8) *bits++ = RATE_6400; /* bit[1], to be compatible with hardware */
else if(len==15) *bits++ = RATE_11800; /* bit[1], to be compatible with hardware */
for (i = 0; i < len; i++)
bits = 0;
for (j = 7; j >=0; j--){
if( (bitstream>>j)&1 )
*bits++ = BIT_1;
else
*bits++ = BIT_0;
return;
