ps_ippi unable to run in KDE
hcostelha
Hi, I'm using IPP4.1 under Linux and the following happends. When I run the test ps_ippi in the konsole under X11 (in KDE on a SuSE Linux Pro 9.1) it stops shortly after having started with the message "OMP abort: stack overlap detected!". If I run it from a terminal window (using Ctrl+Alt+F2 for instance) it runs without any problem.
What can I do?? Does this bring any problems to my code, or just to your tests?
Hugo
Vladimir_Dudnik
actually it looks like you have different environment settings in console and in terminal. Could you please verify that variables PATH, LD_LIBRARY_PATH and so one are the same? I belive you need to have libguide.so accessible through env variables.
Vladimir
hcostelha
Actually I don't use the variable LD_LIBRARY_PATH. Instead I upadte the file /etc/ld.so.conf, so that it works for every user that logs into the computer. I simply had
/opt/intel/ipp/ia32_itanium/sharedlib
/opt/intel/ipp/ia32_itanium/sharedlib/linux32
to that file and everything worked well until now. In previous IPP versions (although I don't garantee that I uses SuSE Pro 9.1 on those times) it worked well. Concerning the $PATH variable, it has the same values.
Cheers.
Hugo
Vladimir_Dudnik
Hi, could you please report about this issue to the premier.intel.com?
Vladimir
hcostelha
Hi would do that, but I don't remember my password (my login is costelha_at_b52.ist.utl.pt) and whenever I try to retrieve the password by following the "Forgot My Password" link I get the following error on Intel's premier site:
"An error occurred on the server when processing the URL. Please try the operation again. If the problem persists, use the feedback link on our home page to report the issue."
I tried with konqueror and the latest mozilla firefox release and got exactly the same result...
I don't remember having problems in the past. Did something changed in the Premier Site?
To whom should I post this problem.
Hugo
Vladimir_Dudnik
I'll ask Ying to check your accaunt info
Vladimir
Ying_S_Intel
Dear Customer,
I have checked your login ID and your email address in our database, we found out there was not registration with this login ID.
If you have a valid Intel IPP serial number from IPP 4.1 evaluation or commercial release, please complete the registration from
https://registrationcenter.intel.com/RegCenter/Register.aspx
Then you will be able to login to Intel Premier Support at https://premier.intel.com and submit an issue.
Hope it helps.
Ying
hcostelha
I didn't quite understand what happened here, but I followed the link ysong gave me and I managed to recover my password for the intel premier site. So I submitted the problem report.
Thanks for the help.
Hugo Costelha
Vladimir_Dudnik
Great! I believe you will be supplied with some solution for this issue.
Vladimir
