6824 Discussions
"Error at loading of ippSP library" error on EMT64 Window 2003 64 Edition (IPP 4.1)
tez
The dialog contains the error message:
"No DLLs were found in the Waterfall procedure".
I did a little research on this message and found a document in the support section that suggested four different solutions to make sure the application has access to the IPP DLL's. I tried each solution, including copying all of the DLL's to the application dir, with no success. Here is the directory listing of DLL's
11/02/2005 04:15 PM 11,797,504 Codejock.ToolkitPro.Mfc80.v9.80D.dll
11/04/2005 01:14 PM 4,311,040 DMFramework.dll
07/20/2004 04:18 PM 60,416 ippacem64t.dll
07/21/2004 05:09 PM 530,944 ippacm7.dll
07/20/2004 04:15 PM 495,104 ippacmx.dll
07/20/2004 11:58 AM 55,808 ippchem64t.dll
07/20/2004 11:58 AM 72,192 ippchm7.dll
07/20/2004 11:57 AM 69,632 ippchmx.dll
07/19/2004 04:00 PM 61,440 ippcoreem64t.dll
07/24/2004 01:04 AM 78,848 ippcvem64t.dll
07/24/2004 01:01 AM 1,138,688 ippcvm7.dll
07/24/2004 01:00 AM 865,792 ippcvmx.dll
07/23/2004 07:23 PM 292,864 ippiem64t.dll
07/23/2004 07:12 PM 5,999,616 ippim7.dll
07/23/2004 07:05 PM 4,973,056 ippimx.dll
07/28/2004 12:56 AM 69,632 ippjem64t.dll
07/28/2004 12:51 AM 595,456 ippjm7.dll
07/28/2004 12:49 AM 480,768 ippjmx.dll
07/19/2004 12:27 PM 526,336 ippmem64t.dll
07/17/2004 05:52 AM 4,375,040 ippmm7.dll
07/17/2004 05:47 AM 4,375,040 ippmmx.dll
07/21/2004 11:34 PM 77,312 ippscem64t.dll
07/21/2004 11:29 PM 927,232 ippscm7.dll
07/21/2004 11:26 PM 649,216 ippscmx.dll
07/20/2004 10:19 AM 193,536 ippsem64t.dll
07/20/2004 10:06 AM 2,587,136 ippsm7.dll
07/20/2004 09:57 AM 1,901,056 ippsmx.dll
07/22/2004 12:02 AM 116,736 ippsrem64t.dll
07/23/2004 05:23 PM 1,768,448 ippsrm7.dll
07/23/2004 06:41 PM 1,124,352 ippsrmx.dll
07/20/2004 10:35 PM 72,192 ippvcem64t.dll
07/21/2004 06:46 PM 578,048 ippvcm7.dll
07/20/2004 10:28 PM 511,488 ippvcmx.dll
07/26/2004 09:36 AM 62,464 ippvmem64t.dll
07/26/2004 09:33 AM 827,392 ippvmm7.dll
07/26/2004 09:32 AM 823,808 ippvmmx.dll
06/08/2004 07:54 AM 235,520 libguide40.dll
37 File(s) 53,681,152 bytes
0 Dir(s) 5,463,719,936 bytes free
Help would be very much appreciated.
Vladimir_Dudnik
Please remember, that cpu-specific DLL for IPP before v5.0 should be located at ipp20 subfolder. In other words, IPP dispatcher looks for ipp20 subfolder when trying to find the appropriate cpu-specific DLL. I recommend you to read IPP technical information from the main IPP page, for example, article Linking with Intel IPP. It also useful to take a look on IPP FAQ, it is availablefrom Technical Support Resources link.
You also might be interested to take a look on the forum discussion of similar questions in the past:
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=1346
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=1374
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=1393
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=1618
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=2695
Hope it helps
Vladimir
Message Edited by vdudnik on 11-08-2005 11:38 AM
