sharing buffers for forward and inverse DCT
piem
Hi, From the documentation, it is not clear weather ippsDCTFwdInit_32f and ippsDCTInvInit_32f can share the same memory space. For a given length, ippsDCTFwdGetSize_32f and ippsDCTInvGetSize_32f do return the same sizes, and allocating the Ipp8u buffers once for both forward and inverse transform seems to work. However, I assume there is a reason for which both pairs of functions exist. Any clue? thanks, piem
Valentin_K_Intel
Hi piem,
The functions ippsDCTFwdGetSize_32f and ippsDCTInvGetSize_32f can return different sizes theoretically. If you would like to share work buffers between the ippsDCTFwdInit_32f and ippsDCTInvInit_32f functions, you should call the both GetSize functions and choose the maximal returned size of work buffers.
Valentin
Valentin_K_Intel
Hi piem,
Valentin
piem
Hi Valentin, Perfect, thank you for the clarification. Best, piem
