6838 Discussions
show the ipp function list which is optimize by AVX or AVX2?
Fu__Yu
Currently I am doing some benchmark comparing the time usage between enable / disable the AVX / AVX2 / SSE. And I found there is no remarkable difference for some math function such as add & multiply. I switch the flag by manually change the cpu variable and call function: ippSetCpuFeatures. Is it reasonable or not?
 status = ippGetCpuFeatures(&mask, 0);
  // chage instruction flag
  //ippCPUID_MMX
  printf("\nBefore set ippCPUID_MMX:      %c\t%c\t", (mask & ippCPUID_MMX) ? 'Y' : 'N', (emask & ippCPUID_MMX) ? 'Y' : 'N');
  if (a = (mask & ippCPUID_MMX))
   emask = (emask - ippCPUID_MMX);
  printf("\nAfter set ippCPUID_MMX:     %c\t%c\t", (mask & ippCPUID_MMX) ? 'Y' : 'N', (emask & ippCPUID_MMX) ? 'Y' : 'N');
  IppSts = ippSetCpuFeatures(emask);
  if (IppSts == ippStsFeatureNotSupported || IppSts == ippStsUnknownFeature) //ippStsNoErr
   wStatus = IppSts;
   goto EXIT;
More detailed pls. refer to below.
Intel Xeon CPU E5-2650 V4 @ 2.2GHz
Image sz: 2048 * 2048
Unit of time: ms
Ipp version
Instruction & Compiler setting
Add
Multiply
SobelX&Y
Integer
 (unsigned char)
Float
Integer
Float
Integer
Ipp New (2018)
AVX2 off + AVX off + SSSE3 off
0.55
5.96
0.67
5.69
14.84
31
Ipp New (2018)
AVX2 off + AVX off + SSSE3 on
0.56
5.99
0.62
5.68
4.29
Ipp New (2018)
AVX2 off + AVX on
0.56
5.99
0.62
5.68
4.49
61439
Ipp New (2018)
AVX2 on
0.56
5.84
0.57
5.61
2.99
Ipp New (2018)
AVX2 on + VS AVX Compiler on
0.54
5.91
0.55
5.72
3.06
Ipp New (2018)
AVX2 on + VS AVX2 Compiler on
0.55
5.85
0.55
5.67
2.98
Thanks & regards,
FY
Fu__Yu
Could you provide a table to show the ipp function list which is optimize by AVX or AVX2?
