6815 Discussions
simple_player does not render in win7 on v7.0.1.046
TatKin_T_Intel
hi,
when using simple_player in v6.1.6.056, i can render video in Win7 OS and i can see that the information as below:
C:\\6.1.6.056\\ia32\\ipp-samples\\audio-video-codecs\\_bin\\Win32\\release_as
cii>simple_player -vblt "C:\\Users\\ttan9\\Desktop\\Taipei101+sunset+WMV+HD+720.mp4"
Audio Render : DSOUND
Video Render : BLT
-RenderFormat: YV12
Stream Type : MP4ATOM
Video Info :
-Video Type : H264
-Resolution : 1280x720
-Frame Rate : 25.00
Audio Info :
-Audio Type : MP1L3
-S.Frequency : 44100
-Num.Channel : 2
-BitPerSample: 16
DecRate:116.91 fps(Dec 7.75ms/f + Conv 0.80ms/f = 8.55ms/f) RndrRate 53.91fps Audio Dec 230.85chnls
DecRate:85.57 fps(Dec 10.85ms/f + Conv 0.84ms/f = 11.69ms/f) RndrRate 26.53fps Audio Dec 178.10chnls
DecRate:89.26 fps(Dec 10.37ms/f + Conv 0.83ms/f = 11.20ms/f) RndrRate 26.19fps Audio Dec 157.34chnls
DecRate:93.63 fps(Dec 9.87ms/f + Conv 0.81ms/f = 10.68ms/f) RndrRate 26.16fps Audio Dec 154.62chnls
DecRate:94.62 fps(Dec 9.76ms/f + Conv 0.81ms/f = 10.57ms/f) RndrRate 27.09fps Audio Dec 150.25chnls
^C
cii>
However, when i use v7.0.1.046, the same commands and same video file was executed and there is no video being rendered out!
see below log:
C:\\7.0.1.046\\ipp-samples\\audio-video-codecs\\_bin\\Win32\\release_ascii>simple_player.exe
-vblt "c:\\Users\\ttan9\\Desktop\\autoeye_small.mpg"
Audio Render : FILE WRITER
Video Render : NULL
-RenderFormat: YV12
Stream Type : MPEG2P
Video Info :
-Video Type : MPEG2
-Resolution : 1920x1080
-Frame Rate : 29.97
Audio Info :
-Audio Type : AC3
-S.Frequency : 48000
-Num.Channel : 2
-BitPerSample: 16
DecRate:102.99 fps(Dec 7.25ms/f + Conv 2.46ms/f = 9.71ms/f) RndrRate 29.79fps Audio Dec 209.09chnls
DecRate:107.69 fps(Dec 7.32ms/f + Conv 1.97ms/f = 9.29ms/f) RndrRate 29.96fps Audio Dec 156.84chnls
DecRate:117.90 fps(Dec 6.66ms/f + Conv 1.82ms/f = 8.48ms/f) RndrRate 29.97fps Audio Dec 146.69chnls
DecRate:116.54 fps(Dec 6.72ms/f + Conv 1.86ms/f = 8.58ms/f) RndrRate 29.97fps Audio Dec 127.75chnls
DecRate:113.06 fps(Dec 6.90ms/f + Conv 1.94ms/f = 8.85ms/f) RndrRate 29.97fps Audio Dec 113.34chnls
DecRate:115.86 fps(Dec 6.72ms/f + Conv 1.91ms/f = 8.63ms/f) RndrRate 29.97fps Audio Dec 110.76chnls
DecRate:116.35 fps(Dec 6.69ms/f + Conv 1.90ms/f = 8.59ms/f) RndrRate 29.97fps Audio Dec 110.64chnls
DecRate:116.78 fps(Dec 6.66ms/f + Conv 1.90ms/f = 8.56ms/f) RndrRate 29.97fps Audio Dec 109.65chnls
DecRate:116.82 fps(Dec 6.67ms/f + Conv 1.89ms/f = 8.56ms/f) RndrRate 29.97fps Audio Dec 109.95chnls
DecRate:116.14 fps(Dec 6.71ms/f + Conv 1.90ms/f = 8.61ms/f) RndrRate 29.97fps Audio Dec 109.72chnls
DecRate:114.30 fps(Dec 6.84ms/f + Conv 1.91ms/f = 8.75ms/f) RndrRate 29.97fps Audio Dec 107.68chnls
^C
note that i have chosen "-vblt" and it shows NULL. while in previous sample (v6.1.6.056) the same command -vblt works well. both codes are running at Win7 OS.
The Audio does not work in v7.0.1.046 as well. Audio works well in v6.1.6.056.
pls see attached pics for reference.
Vladimir_Dudnik
could you please attach sample test stream which does not work?
Vladimir
TatKin_T_Intel
hello Vladimir,
my bad. i had attached wrong info earlier on. here is the log streams using the same file as i had used in v6.1.6
Log:
C:\7.0.1.046\ipp-samples\audio-video-codecs\_bin\Win32\release_ascii>simple_player.exe
-vblt "C:\Users\ttan9\Desktop\Taipei101+sunset+WMV+HD+720.mp4"
Video Render : NULL
-RenderFormat: YV12
Video Info :
-Video Type : H264
-Frame Rate : 25.00
Audio Info :
-Audio Type : MP1L3
-Num.Channel : 2
-BitPerSample: 16
DecRate:251.36 fps(Dec 2.78ms/f + Conv 1.19ms/f = 3.98ms/f) RndrRate 25.01fps Audio Dec 201.27chnls
DecRate:748.68 fps(Dec 0.52ms/f + Conv 0.82ms/f = 1.34ms/f) RndrRate 25.00fps Audio Dec 170.76chnls
DecRate:838.20 fps(Dec 0.37ms/f + Conv 0.82ms/f = 1.19ms/f) RndrRate 24.84fps Audio Dec 170.31chnls
DecRate:871.89 fps(Dec 0.33ms/f + Conv 0.82ms/f = 1.15ms/f) RndrRate 24.89fps Audio Dec 170.31chnls
DecRate:863.58 fps(Dec 0.31ms/f + Conv 0.85ms/f = 1.16ms/f) RndrRate 24.92fps Audio Dec 170.31chnls
DecRate:886.33 fps(Dec 0.29ms/f + Conv 0.84ms/f = 1.13ms/f) RndrRate 24.94fps Audio Dec 170.31chnls
DecRate:896.69 fps(Dec 0.29ms/f + Conv 0.83ms/f = 1.12ms/f) RndrRate 24.95fps Audio Dec 170.31chnls
^C
note that there is no rendering found and no audio as well when using this v7.0.1.046 sample.
Chao_Y_Intel
Can you try to use the DX render in the IPP 7.0 sample code? For example:
>simple_player.exe -vdx "C:\Users\ttan9\Desktop\Taipei101+sunset+WMV+HD+720.mp4"
In IPP 7.0 sample code, the BLT render is disabled by default, only the DX render is enabled. You can check the umc_defs.h file for the enabled video render.
Chao
Chao_Y_Intel
Thanks for the update.
Regarding the DX render: 7.0.1.041 is with a recommended implementation to disable Win7 Aero (dx_drv.cpp)"
Actually this is old problem, which was fixed in the 7.0 release. So it does not need to change any code. I run the test with the Aero on in Win7, it can work well in the 7.0.1.041 sample.
Chao
