size limitation with the MKL library
mjrodri
Hello
We are working with the Intel-MKL free evaluation library. (We also use Compaq Visual Fortran 6.6 as you recommend). The problem we want to solve is to calculate the pseudoinverse matrix by using the DGESVD routine (i . e. single value decomposition with the double precision option). However we have experience linking problem as the dimension of the matrix we must work is very high (200.000x 200.000).
There are no problems when linking for a 3000x 3000 matrix and the programs run. We have no problem. When we try to increase the NMAX, MMAX parameters up to 4000x4000 matrix dimensions, we obtain the following warning message:
LNK4084: total image size 86579096 exceeds max <268435456>; image may not run
Our questions is Where is the limit INTEL MKL library and Compaq Visual Fortran 6.6 for the keys we have explained above?
The limit is only in the RAM of the machine where its running or if we get another bigger machine then We`ll still have problems with Intel-MKL library and visual Fortran ?
It is very important for us to know if for the dimension matrix we need to work (200.000x200.000) the limits are imposed by the machine performances or by also Intel MKL library and Compaq Visual Fortran.
Thank you very much in advance for your interest
PD: We will be very thankfull if you could advice us in the way we can manage with this problem
