6814 Discussions
static linking with IPP 8.1 -> error ipps-8.0.dll is missing
Jan_W_1
I have a dll project in VS2013 and IPP 8.1 installed. I'm linking the project statically with the ipp 8.1 by setting the option "Use Intel IPP" to "Single-threaded Static Library" in the VS2013 project settings.
The project compiles fine and all the files are found.
However, when I try to load the dll (the final dll of the project, not any intel dll) I get an error that the dll could not be loaded because:
"ipps-8.0.dll is missing".
I don't know why it tries to load the ipps-8.0.dll because I'm using static linking and I'm not using version 8.0 but version 8.1.
Any help appreciated.
Jan Weigel
Jan_W_1
Sorry, please ignore this post.
It was just an update error and had nothing to do with the linking.
Problem solved.
Bandaru__Raja
Hi Jan. Great to see this post as I have exactly the same problem. However, I didn't understand how you solved this. What update have you done? Thanking you in advance.
