suspicious code in JPEG Samples for Windows
goldfita
I have been working a bit with the IPP JPEG samples.
Package ID: w_ipp-sample-jpeg_p_5.1.1.001
Package Contents: Intel IPP JPEG Samples for Windows*
I noticed the following code in enchtbl.cpp always copies 256 bytes even though the arrays passed to it are less than that length.
ippsCopy_8u(vals,m_vals,256);
By stepping through the code, it's clear that m_vals is getting not just vals copied to it, but the memory following that as well. This does not seem to be causing a problem; although, it might if different compiler options were used.
I don't need a response to this, thanks.
Vladimir_Dudnik
Thank for informing about that. The m_vals is defined in enchtbl.h as an array of 256 Ipp8u, so it should not be overwtitten with copying 256 values into it.
I'm agree that interface for CJPEGEncoderHuffmanTable::Init() should define the length of input vals and bits. Better if change to something like that
JERRCODE CJPEGEncoderHuffmanTable::Init(
int id, int hclass, Ipp8u bits[16], Ipp8u vals[256])
Number 256 itself is maximum possible number of huffman values. In codec we always allocate memory enough for maximum possible number of values, even if some memory will not be used in real application.
Vladimir
goldfita
The problem is vals, not m_vals. Take a look at what is coming into the function (DefaultLuminanceDCValues).
const
Ipp8u DefaultLuminanceDCValues[] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07,0x08, 0x09, 0x0a, 0x0b};
The program does not crash because the copy function reads into memory within the program's data space.
Vladimir_Dudnik
Oh my goodness! You are absolutely right, that is a bug which should be (and will be) fixed.
Thanks for catching that!
Vladimir
