the problem of ipp
yifengyt
When I downloaded the ipp library in oneAPI and Source setvars.sh, I found that I could not find the IPP library.
in cmakelists:
in findIPP.cmake
cmake_policy(PUSH)
cmake_minimum_required(VERSION 2.6)
cmake_policy(POP)
#IF( NOT IPP_FOUND )
FILE(GLOB IPP_INCLUDE_PATHS_0 "/opt/intel/oneapi/ipp/latest/include")
FILE(GLOB IPP_INCLUDE_PATHS_1 "/opt/intel/oneapi/ipp/latest/include")
FILE(GLOB IPP_INCLUDE_PATHS_2 "/opt/intel/oneapi/ipp/latest/include")
SET(
IPP_INCLUDE_PATHS
${IPP_INCLUDE_PATHS_0}
${IPP_INCLUDE_PATHS_1}
${IPP_INCLUDE_PATHS_2}
FIND_PATH(
IPP_INCLUDE_DIR
ippi.h
${IPP_INCLUDE_PATHS}
SET(IPPROOT "${IPP_INCLUDE_DIR}/..")
if(WIN32)
find_path(IPP_PATH "ippi.dll"
PATHS ${CMAKE_PROGRAM_PATH} ${CMAKE_SYSTEM_PROGRAM_PATH} ${IPPROOT}
PATH_SUFFIXES bin
DOC "The path to IPP dynamic libraries")
if(NOT IPP_PATH)
find_path(IPP_PATH "ippiem64t-${v}.dll"
PATH_SUFFIXES bin
endif()
endif()
if(UNIX)
find_path(IPP_PATH "libippi${CMAKE_SHARED_LIBRARY_SUFFIX}"
PATHS ${CMAKE_LIBRARY_PATH} ${CMAKE_SYSTEM_LIBRARY_PATH} ${IPPROOT}
PATH_SUFFIXES lib studlib sharedlib
if(NOT IPP_PATH)
find_path(IPP_PATH "libippiem64t${CMAKE_SHARED_LIBRARY_SUFFIX}"
endif()
endif()
if(IPP_PATH)
file(GLOB IPP_HDRS "${IPP_PATH}/../include")
if(IPP_HDRS)
set(IPP_FOUND TRUE)
endif()
endif()
add_definitions(-DHAVE_IPP)
include_directories("${IPP_PATH}/../include")
link_directories("${IPP_PATH}/../sharedlib")
file(GLOB em64t_files "${IPP_PATH}/../lib/*em64t*")
set(IPP_ARCH)
if(em64t_files)
set(IPP_ARCH "em64t")
endif()
set(A ${CMAKE_STATIC_LIBRARY_PREFIX})
#set(B ${IPP_ARCH}${CMAKE_STATIC_LIBRARY_SUFFIX})
set(B ${IPP_ARCH}${CMAKE_SHARED_LIBRARY_SUFFIX})
if(WIN32)
set(L l)
else()
set(L)
endif()
set(IPP_LIBS ${A}ippcore${B} ${A}ipps${B} ${A}ippi${B})
# ${A}svml${B} ${A}imf${B} ${A}iomp5${B} ${A}irc${B} ${A}pthread${B})
and there is:
AbhishekD_Intel
Please give us the steps that you are following to download and install IPP.
If you have already installed the complete Intel OneAPI BaseKit then no need to download it again and you will get the complete setup to use the IPP library.
So please give us more details on the complete steps that have followed/following to install IPP with oneAPI.
Warm Regards,
Abhishek
AbhishekD_Intel
Please update us with the details.
Thank You
AbhishekD_Intel
We haven't heard back from you for a long time. So we are assuming that your issue has resolved.
We will no longer monitor this thread.
Please post a new thread if you have any other issues.
Warm Regards,
Abhishek
