umc_video_sizing.cpp uses deprecated ippiResize
arvinzchan
Is there a plan to update the UMC samples to remove the deprecated function calls? umc_video_sizing still uses deprecated ippiResize in both the 6.1 and 7 code samples.
Chao_Y_Intel
Thanks for your reporting. There calls should be changed. I will forward it to engineer owner to update the sample. To change the cod now, it only needs toreplace ippiResize_xx with ippiResizeSqrPixel_ calls, and fill xShift/yShift parameters with 0.
Chao
Chao_Y_Intel
The deprecated function has been replaced with ippiResizeSqrPixel since IPP 7.0.2 release.
thanks,
Chao
