6822 Discussions
unresolved link errors -- one way to eliminate rid of many of the common errors
PaulF_IntelCorp
IPP Link Problem:
Link errors, like the dreadedunresolved external symbol error, keep cropping up and you cannot figure out which IPP lib files should be part of your link list when building your IPP application.
Solution:
By default, the linker only includes, or extracts, those functions, or library members, that your application requests. In this case, it is perfectly acceptable to list ALL the IPP lib files in your link list. Using this approach can significantly simplify your build process bookkeeping. (Caution, a few rules do still apply.)
To learn more, read the following KB article:
Simplified Link Instructions for the IPP Library
http://software.intel.com/en-us/articles/simplified-link-instructions-for-the-ipp-library/
Works for me, does it work for you?
Chao_Y_Intel
This way makes linkage much easier. : -)
In Linux system, the library order is also important for static libraries. It needs to put *merged.a library after related *emerged.a library, and ippcore.a is put after *merged.a and *emerged.a libraries.
Chao
PaulF_IntelCorp
Chao,
Thank you for that clarification :) I have updated the article to reflect that basic rule of ordering.
Paul
