using IPP - MPEG2 AAC
Deleted_U_Intel
Hello. I'm Min-chul. Now I'm substituting some functions at MPEG4 BSAC source code for some functions at IPP (MPEG2 AAC), for example,IinverseQuant/MS/IS/TNS/IMDCT to accelerate my decoder. (Is there anyone who have a job like mine?)
But I have a problem. A frame which uses only a long window is decoded well whilea frame whichuses8 short windows is not decoded. As my decoder meets a frame which use 8 short windows, decoder is terminated. Please adviseme.
Intel_C_Intel
Hello Min-chul.
What platform do you use, IA or PCA? What operating system (linux or windows)?
Could you also give us AAC data which cause the error?
Vladimir
Intel_C_Intel
I will clarify your questions with IPP developers. By the way, you can submit these questions through QuAD service, where we can track progress and so on.
Vladimir
Intel_C_Intel
I mean premier.intel.com which is official channel for technical support of Intel products.
tonykwon
Hello !
I am porting BSAC decoder using IPP 4.1 same as min-chul.
And I found the same problem min-chul described exactly.
If you have solved the problem, please give me some information.
Vladimir_Dudnik
please submit your issue to premier.intel.com it will helps us to track the issue and to plan when we can fix it
Vladimir
manjunath_bommanahal
Vladimir
I'm also facing the same kind of problem in replacing IMDCT function in MP3 Decoder. There appears to be some kind of noise introduced after replacing the IMDCT function with the IPP library call. I'm using IPP library for Linux OS ( ubuntu 8.04) . Kindly let me know the reason.
Manjunath.
Vladimir_Dudnik
did you have a chance to try IPP audio-video-codecs samples? We provide several simple applications which demonstrate how to build media codecs based on IPP functions.
Vladimir
