[vb.net] save jpeg
t_goral
Hi all,
How to encoder picture to jpeg format.
I have buffer in format YUY2, 32x32, 352x288 and many else.
I want save jpeg format to my biger file.
I get samples for visual basic, jpeg, image processing and not understanding to many function.
Best regards
Tomasz Goral
Vladimir_Dudnik
Hi Tomasz,
I think it might be easier for you to build JPEG-IJL sample, which is IPP implementation of Intel JPEG Library in DLL, then you may use DLL from your VB program. It will be simplier then implementing the whole JPEG codec on VB with low-level IPP functions.
Vladimir
t_goral
I convert samples from vb6 (for il15.dll) to vb.net:
Public Declare Function ijlErrorStr Lib "ijl20.dll" ( ByRef code As IJLERR) As Integer 'pointer to C-style string
Public Declare Function ijlGetLibVersion Lib "ijl20.dll" () As IntPtr 'Integer 'pointer to IJLibVersion...
Public Declare Function ijlWrite Lib "ijl20.dll" ( ByRef jcprops As JPEG_CORE_PROPERTIES, ByVal iotype As IJLIOTYPE) As IJLERR
Public Declare Function ijlRead Lib "ijl20.dll" ( ByRef jcprops As JPEG_CORE_PROPERTIES, ByVal iotype As IJLIOTYPE) As IJLERR
Public Declare Function ijlFree Lib "ijl20.dll" ( _
ByRef jcprops As JPEG_CORE_PROPERTIES) As IJLERR
Public Declare Function ijlInit Lib "ijl20.dll" ( _
But now have some errors, unable to load dll ijl20.dll
.exe file and ijl20.dll is same directory
registry regsrv32 ijl20.dll return: LoadLibrary(ijl20.dll) failed
What wrong?
Tomasz Goral
Vladimir_Dudnik
Tomasz,
IJL is not an active x control, you do not need to register it with regsrv32.
Vladimir
loofemmaps
I think your best bet would be to stop what you are doing right now, and go and learn English instead of making life more difficult for people like me who are trying to work out what the hell you are on about!
