FFT 3D
mickeyhah
Hallo,
I want to ask about how we perform FFT3D. Actually I already did it, but the result is different from what I expected.
Here is my code
ippiFFTInitAlloc_C_32fc(&spec2D, 4, 3, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone);
for (k=0; k
//dst: 2-dimensional array
status2D = ippiFFTFwd_CToC_32fc_C1R((Ipp32fc*)input+NX/2*NY*k, 16*sizeof(Ipp32fc), dst2D, 16*sizeof(Ipp32fc), spec2D, NULL);
//spread the 2D array to 1D array.
for (i=0; i
dst_tmp[k*NX/2*NY+i]=dst2D;
ippiFFTFree_C_32fc(spec2D);
status1D=ippsFFTInitAlloc_C_32fc(&spec1D, 9, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone);
status1D = ippsFFTFwd_CToC_32fc(dst_tmp, output, spec1D, pBuffer1D);
ippsFFTFree_C_32fc(spec1D);
Aremy code and my method for calculating FFT3D correct?
Thank you for your help
Anh Ngo
Vladimir_Dudnik
there is comment from our expert:
FFT3D for NX * NY * NZ can be splitted into two phases,
1. NZ calculation of FFT2D for size NX * NY
2. NX * NY calculation of FFT1D for NZ size
so recomendation is to use something like this
NX = 1<
NY = 1<
NZ = 1<
ippiFFTInitAlloc_C_32fc(&spec2D, orderX, orderY, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone);
for (k=0; k
status2D = ippiFFTFwd_CToC_32fc_C1R((Ipp32fc*)input+NX*NY*k, 16*sizeof(Ipp32fc), (Ipp32fc*)output+NX*NY*k, 16*sizeof(Ipp32fc), spec2D, NULL);
status1D = ippsFFTInitAlloc_C_32fc(&spec1D, orderZ, IPP_FFT_DIV_INV_BY_N, ippAlgHintNone);
for (i=0; i
for (j=0; j
for (k=0; k
tmp=output[i+NX*j+NX*NY*k]
status1D = ippsFFTFwd_CToC_32fc(tmp, tmp, spec1D, pBuffer1D);
for (k=0; k
output[i+NX*j+NX*NY*k]= tmp;
Vladimir
mickeyhah
Hallo,
Thank you for your quick response.
Now I want to do the FFT3D inverse, so I have to do in the same way but in the reverse order. That means
1. NX * NY calculation of FFT1D inversefor NZ size
2. NZ calculation of FFT2D inverse for size NX * NY
Is that correct?
Anh
Vladimir_Dudnik
Yes, that's correct. Note, that FFT3D is also available in Intel Math Kernel library
Vladimir
