where can I find audio_codec_con sample code
jachu19
I'm new here.
Where can I find/download audio_codec_con sample application (missing in IPP 6.x samples).
I need aac audio encoder sample code.
I was looking for older IPP 5.x samples, but no working link found. Is it not free anymore?
VipinKumar_E_Intel
You can find the the aac encoder sample for 6.xin the Main Samples from http://software.intel.com/en-us/articles/intel-integrated-performance-primitives-code-samples/
jachu19
w_ipp-samples_p_7.0.1.041\ipp-samples\audio-video-codecs\application:
simple_player
umc_h264_dec_con
umc_video_enc_con
but no audio encoder example (same for 6.x). I already started developing it basing on umc-manual.pdf and I see it is quite easy, but working example helps to check the results.
Naveen_G_Intel
AAC encoder is part of 'codec folder' in the sample code, refer to \ipp-samples\audio-video-codecs\codec\aac_enc
Naveen Gv
Tamer_Assad
Innovator
Hi Jachu,
You may use the umc-manual.pdf, there is a usage sample for the AAC encoder. You can integrate it into the sample-player sample and test it.
Tamer Assad
