Intel® MPI Library
2302 Discussions
[BUG] Compiling with LLVM-based Intel MPI compilers (oneAPI)
Diehl__Martin
Describe the bug
configure stops with error. It is invoked with
./configure CC="mpiicc -cc=icx" CXX="mpiicpc -cxx=icpx" F90="mpiifort -fc=ifx" FC="mpiifort -fc=ifx" F77="mpiifort -fc=ifx" --enable-shared --enable-parallel --enable-fortran --with-zlib=yes --with-szlib=no
Expected behavior
Installation with Intel oneAPI LLVM compilers should be possible
Platform (please complete the following information)
  • HDF5 1.12.2
  • Arch Linux (Kernel 6.0.2-arch1-1)
  • Intel oneAPI 2022.3.0.8767 (BaseKit + HPCKit)
  • Gnu Make 4.3
Additional context
It seems that configure finds the classic intel compilers
  • compiler 'mpiicc -cc=icx' is Intel icc-2022.2.0
  • compiler 'mpiifort -fc=ifx' is Intel ifort-2022.2.0
  • compiler 'mpiicpc -cxx=icpx' is Intel icpc-2022.2.0
see also https://github.com/HDFGroup/hdf5/issues/2186
SantoshY_Intel
Thanks for posting in the Intel forums.
Could you please let us know if you are facing any errors while configuring HDF5 using the Intel oneAPI compilers(icx,icpx,ifx)?
Thanks & Regards,
Santosh
Diehl__Martin
./configure CC="mpiicc -cc=icc" CXX="mpiicpc -cxx=icpc" F90="mpiifort -fc=ifort" FC="mpiifort -fc=ifort" F77="mpiifort -fc=ifort" --enable-shared --enable-parallel --enable-fortran --with-zlib=yes --with-szlib=no
works. I think the issue is that the build system cannot discriminate the compilers and uses options or expects behavior that work for the traditional compilers but not for the new ones.
SantoshY_Intel
Could you please confirm if you are facing a similar error as shown below? If not, please provide us a screenshot of the error you are facing.
Thanks & regards,
Santosh
Diehl__Martin
I can confirm that. I think the interesting information is in the this statement from config.log:
/usr/bin/ld: cannot find -loopopt=1: No such file or director
to me it seems that there is a dash missing and it is interpreted as a single character statement -l='oopopt=1'
SantoshY_Intel
We Assume that your issue is resolved. So could you please confirm to close this issue?
Thanks & Regards,
Santosh
SantoshY_Intel
I assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
