Intel® MPI Library
2288 Discussions
Bug in mpi_f08-module with IMPI-5.1.1.109&Intel-16.0.0 on Linux-cluster
Michael_R_2
Dear developers of IMPI
I observed a bug when using the mpi_f08-module with IMPI-5.1.1.109 & intel-16.0.0
when running a Fortran program with 2 MPI-procs on a LINUX-cluster.
Data are not correctly transmitted by MPI_GATHER and by MPI_BCAST.
a) MPI_GATHER: The following bug occurred only with mpi_f08-module, whereas with mpi-module it worked
A simplified code snippet looks like that:
integer , parameter :: mxhostlen=128
character(len=mxhostlen) :: HOST_NAME
character(len=mxhostlen), allocatable, dimension(:) :: nodename_from_irankWORLD
! Note: numprocsWORLD is the number of MPI-procs running
if(lmaster) then ! <-- rank 0
allocate( nodename_from_irankWORLD(0:numprocsWORLD-1) )
else
allocate( nodename_from_irankWORLD(0:0) ) ! for saving storage on the slave procs
endif
call MPI_GATHER( HOST_NAME , mxhostlen, MPI_CHARACTER &
,nodename_from_irankWORLD, mxhostlen, MPI_CHARACTER &
,0_INT4, MPI_COMM_WORLD, ierr_mpi )
Using this for gathering the hostnames from each process on the master process, I get:
[0] Fatal error in PMPI_Gather: Message truncated, error stack:
[0] PMPI_Gather(1303).......: MPI_Gather(sbuf=0xa8e160, scount=128, MPI_CHARACTER, rbuf=0x26402d0, rcount=1, MPI_CHARACTER, root=0, MPI_COMM_WORLD) failed
[0] MPIR_Gather_impl(728)...:
[0] MPIR_Gather(682)........:
[0] I_MPIR_Gather_intra(822):
[0] MPIR_Gather_intra(187)..:
[0] MPIR_Localcopy(125).....: Message truncated; 128 bytes received but buffer size is 1
You see, that the value of rcount= is 1 but should be 128 (=mxhostlen).
If I change the call of MPI_GATHER into this stmt:
,nodename_from_irankWORLD(0), mxhostlen, MPI_CHARACTER &
then it works, but nevertheless this is also a bug, because there must not be any influence,
whether the starting address of the receiving choice buffer
is actually the starting address of the array or the address of its 1st array element
or the address of a (sufficiently long) variable)
b) MPI_BCAST: the following bug occurred only with mpi_f08-module, whereas with mpi-module it worked
integer , parameter :: mxpathlen=512
character(len=mxpathlen), save :: CONF_DIR
character(len=mxpathlen), dimension(1) :: cbuffarr
integer :: nelem, lenelem, lentot, ierr_mpi
nelem=1
lenelem=mxpathlen
lentot= nelem * lenelem ! total number of characters to be transmitted
!!! call MPI_BCAST( CONF_DIR , lentot, MPI_CHARACTER, 0, MPI_COMM_WORLD, ierr_mpi ) ! <--did work
cbuffarr(1)= CONF_DIR
call MPI_BCAST( cbuffarr , lentot, MPI_CHARACTER, 0, MPI_COMM_WORLD, ierr_mpi ) ! <--did not work
!!! call MPI_BCAST( cbuffarr(1), lentot, MPI_CHARACTER, 0, MPI_COMM_WORLD, ierr_mpi ) ! <--did work
CONF_DIR=cbuffarr(1)
Using this to transmit a string from the master to all slaves,
I get not an error message, but the string sent is not received on the slaves!
Possibly these bugs are also in the interfaces of other MPI-routines of the mpi_f08 module?
Greetings
Michael
Gergana_S_Intel
Hi Michael,
Thanks for letting us know.  We recently received another issue with a similar root cause so I've added your name and reproducer to our internal bug.  The problem seems to stem from Intel Fortran compiler's newly added support for F08.  I'll update again once the fortran engineers have had a chance to investigate.
~Gergana
Gergana_S_Intel
Hi Michael,
Just a heads-up since we've  had a development on this internally.  The Intel Fortran Compiler team determined what the issue was and have fixed it in an internal build.  This fix for F08 will be included in one of the upcoming releases for the compiler (likely an update to the 16.0 version).
Once the next release is out, you're welcome to download it and test it.
~Gergana
